Finish for steel
Finish for steel
Finish for steel
Randy Stukenberg
I made a table out of a walnut slab supplied by a customer and had a metal base made by a welder. It is 1" square steel tubing. The customer wants a clear finish. Should I just use a coat or two of furniture wax? I'm afraid a spray coat of lacquer would eventually flake off. Any other ideas? Thanks!
Re: Finish for steel
John McGaw
If you really want to do it up right and you have access to a company in your area that does powder coat paint then your answer might lie there since clear powder is a real thing. The real question might be what you want to do with the metal before the coating is put on since all sorts of cleaning and treating options exist. I'd probably go for fine media blasting but tastes vary.
Grant Smith
Part of the powder coating process is an involved cleaning process. Before you commit, ask the coating shop what the steel you have used look like after it is clear coated. Some use chemical baths, some use sand or media blasting. It may or may not retain its current look, and depending on any sample they may show you it may be a good look or not.
I would recommend this if you like the look your powder coating shop can provide.
FWIW,
Grant in Iowa
Ive been using Tung oil.
Robin Corell in Atascadero
Tung oil finish works great if it will always be indoors. Ive been doing a series of artworks made out if steel that have some pretty wild patinas, along with copper and silver plate. heating the steel and applying a coat of paste wax while the metal is still warm works, but it does not make the steel immune to rust. A couple of coats of Formby's tung oil finish wiped on does a much better job of protecting against rust.
The piece below is mild steel, the piece in the center has a black patina that has been mostly removed leaving a brushed finish. The upper background area has silver plate and the bottom has a patina. all of these finishes are sensitive and would change if left unsealed or un-treated in some way. Its been over a year since I finished this and it has not changed at all while a control sample with no finish has changed considerably.
ken combs
That really depends on the look your customer wants. Polished bright steel, satin finish but silver, steel color, dark finish like hot rolled steel? Lots of possibilities.
Any film finish will require some sort of really good cleaning/prep to get it to adhere well.
You can clean the steel without disturbing/changing the color with wax/grease remover or strong detergent.
If it were mine, I'd lightly sandblast and coat with an automotive clear urethane. That would be a silverish color, and the sheen could be anywhere between flat to really shiny, depending on the flattener content in the clear.
But it's not mine.
ken combs
forgot to add: My finish preference would be the mentioned urethane, no matter what the prep or underlying metal color. Because it is nearly as tough as powder coat, and lots cheaper/faster to accomplish.
Does paint flake off a car? Why flake off yours?
Dick Coers
Lacquer has a better chance of staying on steel versus wood if you clean the steel. Steel doesn't expand nearly as much as wood.
Ralph Lipeles
I used to restore lots of vintage lamps with brass parts. I would first clean them real good with soap and water to remove all traces of the wax based buffing compound. Then they cannot be touched any more with fingers. All lifting and moving must be with cotton gloves or pieces of paper towels. If there is any doubt of how well the parts were cleaned, give them a rub or 2 with a piece of paper towel saturated with lacquer thinner. After cleaning spray with 2 or 3 coats of lacquer. The lacquer coating will not permit any air to get to the base metal and will protect the metal for many decades.
Steve Schoene
Formby's Tung Oil Finish isn't tung oil, it's a soya based varnish. A pretty decent interior varnish, with a moderate amber color.
TomD
If you sand blast it, you can get a chemical bond to the steel for a period of time after blasting. You can see this preparedness by whether a liquid like water wets the surface, or whether the water forms droplets. Normally this kind of prep is only good for a mater of hours.
