Dust collection for a Dewalt DW735 planer
Bruce, a MN Galoot
Those of you who have this planer know that it spits out chips with a tremendous amount of force. The first time I was surprised to see them landing 20 ft away. I made a rudimentary chip collector from a garbage can with a Thien baffle and a lid on the top. It worked okay, but not much more than that. The big problem was that I couldn't seal the top enough to prevent the chips from leaking out the side and spitting out onto the floor. Those little buggers still go 6-8 ft.
Well, I just made a wooden canister from some 1/16" plywood (from a roll of discarded veneer, really), reinforced with a couple rings around the top. Think of a 20" Sonotube with a lid on top. There's a Thien baffle about 6" down from the top. Upon first trying it out, the pressure from the planer fan forced the lid off the canister. So I screwed it down in two places, still not enough. Now I have it screwed down in four places and little chips are still being blown out.
Is there some way to reduce the pressure from the chip collector on the planer or do I have to re-think how to collect those little buggers. What am I missing?
I don't have a conventional dust collector, and right now don't have the room for one, either.
Re: Dust collection for a Dewalt DW735 planer
I made an interceptor for the chips out of a Rubbermaid trash can. I have not used it in a long time but I connected the shop vac to the out let on it to suck the air out about as fast as it went in thus reducing the pressure on the cracks. The alternate problem was that the shop vac would collapse the trash can. I had to reinforce it with sticks up the corners.
The suggestion here is to use a shop vac to reduce the internal pressure.
Bruce, a MN Galoot
I'm not sure my shop vac has enough suck to do that, but at the very least I need to provide a bigger vent. The intake side is 4" so I though that would suffice for exhaust, but it seems not. I'll try for bigger.
Thanks, Barry.
I was thinking about that. I think the outlet should be larger than the inlet to allow the air to exit at low speed and pressure. If you drop the exit velocity the debris should fall out in the collector.
GolfSteve in Calgary
Look up the DW735 chip collection accessory. It's basically a flexible hose and a bag. One came with my DW735. I think it worked not too bad - but it wasn't perfect. Soon after I bought a central dust collector, which is much better.
Joe Kaufman
It would be interesting to try discharging the planer through a Oneida Super Dust Deputy 4" Cyclone Separator. It should work as well push through as pull through. I believe the shop vac Dust Deputy would be too small for the volume generated.
Bruce, a MN Galoot
Thanks for that. I didn't know there was one such product.
Bruce, a MN Galoot
I think that would work pretty well. I'm going to try a homebuilt, modified version of that first, and if that doesn't work I'll have to bite the bullet and buy one.
AZ in Colorado Springs
My planer (rigid) gets hooked up to a rockler vortex separator and a shop vac. The vortex fills quickly unless I'm planing just a few small boards.
A couple of times, working large projects during cold weather, I've taken the planer to the wood hobby shop on the Air Force Academy and hooked it up to the dust collector. Works much better then. (Of course there is a big planer at the shop, but as some have noted in other threads, the smaller planer can produce a nicer surface.)
I have a cyclone dust collector. It works fine w/ my DW735 :). When I take it out of the shop for a spin (rarely) - I use the circular connection hooked to a piece of 4" hose (about 4-5' long) - the same one I use to hook it to the blast gate. By the time it gets to the end of the hose, a lot of the energy is spent and will go into a trash can collector nicely.
