The important question is...
..can I use them before they are dry? No, for most furniture.
It doesn't matter how they get dried.
If you live in Arizona they are already dry. If you live in a place with 40" of precipitation and winter, they most surely are not, nor will they ever be piled outside.
Drying is simple to understand. Wood will equilibrate with the relative humidity of its surroundings. You can find tables on the Internet correlating humidity and moisture content. How low you need to go depends on your design skills and experience and what you are building. Commercial specification is 7%. You will never get there without heat.
How quick it equilibrates depends mainly on temperature. In a kiln, its fast. Under you bed, slower. Up in a loft, somewhere in between.
If you have a good scale you can best determine moisture content with it and the kitchen oven.
Lumber that thick is hard to dry reliably. I don't recommend taking it to a kiln for there is a good chance they will dry it too fast.
