OT: Cleaning Alkaline Battery Corrosion
Bill Howatt
Any magic formulation for cleaning up mess a leaking alkaline battery made?
IMO, they have changed, when they first came out I got the impression leaking was a thing of the past remembering many carbon-zinc experiences. Now I find they are much better than carbon-zinc but nowhere as good as they once were - including the much praised Duracells.
Bill
Re: OT: Cleaning Alkaline Battery Corrosion
John C Lucas
I used to do camera repair. Make a paste of baking soda and wipe or brush it over everthing contaminated. Then clean it with electrowash.
William Duffield
I stopped using DuraCells because they are notorious for leaking and for not honoring their warranty. I switched to Kirkland, which are a much better deal, even if you replace the Duracells on time. The Costco brand batteries don't have as much power as the DuraCells, but the much lower price and lack of corrosion more than makes up for the slightly shorter life.
water
The white stuff is mostly potassium carbonate. It will be soluble in water. There may be some zinc carbonate present. If this white residue remains then use some vinegar. I have never seen the manganese leak out. It will be black and harder to be rid of.
Bicarbonate is for cleaning lead acid batteries.
Gary Smyth
My remedy. Use a old toothbrush to brush away any loose white stuff. Place a small amount of white vinegar and with a Qtip, wet then wipe the contacts.
Follow up with a light swipe or two of 400 grit paper on the contact(s).
From the web.
Cleaning the battery compartment following these steps should not affect the recording.
1.Put on disposable protective gloves (nitrile, rubber, or other material).
2.Open the battery compartment containing the damaged/leaking batteries.
3.Carefully remove the damaged batteries and place each battery in a separate sealable plastic bag.
4.Use a disposable towel to brush away any loose corrosion (white solid).
5.Place a small amount of white vinegar into a small container such as a cup or bowl.
6.Using a cotton swab, moisten the tip with vinegar and carefully wipe the corroded contacts. Repeat as necessary to remove all of the white residue.
7.Using a fresh cotton swab, moisten the tip with water and wipe the contacts again to remove the vinegar residue.
8.Dry the contacts with a disposable towel or fresh cotton swab and place new batteries into the compartment.
Wipe down the work area with a damp cloth. Dispose of all used items. Take the bagged batteries to your local battery recycling or hazardous waste drop off center. If these services are not available, place the bagged batteries in the trash.
use vinegar  white will work
Thanks Everybody!
