OT - Painting Radiators?
William Duffield
I'm painting several rooms in my house. For each room, "we" have picked the wall color and the trim color. Should the radiators (cast iron) be painted the same shade as the walls or the same shade as the trim?
Re: OT - Painting Radiators?
John Veerkamp
do you want them to fade somewhat into the background or be more noticeable?
The color may change some with the heat of the radiator so the this into consideration in your decisions. Doesn't even need to be the same in each room.
Black
they will radiate best when black. However, if you intend to ignore radiation fundamentals then some other color could be used with a sacrifice in heating efficiency. Best would be to not paint them at all. The insulating properties of the paint lessens efficiency too. :)
Re: Black
William Duffield
It's a hot water system. Most of the heat transfer is by pump from the boiler to the "radiators", and then by conduction from the water through the cast iron to the air, and then by convection throughout the room. This type of system provides a lot more even temperature, without the extreme drying effects of forced air systems, that "blow hot and cold." The radiators already have a hundred years, at least, of paint on them, mostly white.
Re: Black
It doesn't matter how the steel gets hot, it still heats the room more by radiation than conduction to the air molecules. Hence, black is best. It will be a simple matter to strip the paint, I presume you don't mind a bit of lead oxide, and paint back if they must be painted our just let them develop a nice iron patina.
Color is essentially irrelevant. *LINK*
Gary Smyth
Metallic content of paint does warrant consideration. For most purposes color is less important than what the room looks like with the radiator exposed. Information is old (1935) but apparently still valid. Long article but worth the read. Bottom of article has a chart.
https://heatinghelp.com/heating-museum/does-the-color-of-a-radiator-matter/
The only way I can see that an exterior color might change efficiency is if it were exposed to a separate heat source such as sunlight or a space heater.
Re: Black
Keith Newton
I agree with Bill on this. My shop double barrel stove is black, and when I've been away allowing the space to cool down, I can feel the radiant heat on my face instantly from 12' away as soon as the fire heats the metal.
Back when our ancestors cooked on a wood stove, those were always white, so grandma could stay in the kitchen without roasting along with the food before air conditioning. If it is white, or mirror, you won't even feel the heat until your hand is in contact with it
Re: Thank You!
William Duffield
My problem is not one of engineering or physics (thermodynamics, specifically). What I need is is an opinion from the point of view of a designer/interior decorator.
My painter is not going to mix up wall colors or trim colors between the parlor and the drawing room, and neither he nor SWMBO will accept either black or shiny metallic radiators.
Jesper, Denmark
Misnomer........
Jesper, Denmark
Even though they are called radiators - even here in Europe, where they are the most common heating system - they are in fact convectors. Heating the air flowing up over the heat transfer surfaces. Typically they are painted with the wall color, not the trim color.
If placed "correctly" under Windows, they are frequently covered in an open lattice work, which is then painted like the window trim.
The limiting heating factor is transfer from the metal to the air. If the water temperature leaving the radiator is close to the room tamperature, there is enough surface and the radiator is large enough.
