THE WOODRAT IS BACK!
Festool Domino question
I just bought a used Domino DF 500. The manual that came with it is sparse in details of how to most effectively use it. Specifically, what is done to ensure the mating parts line up? Is using the aiming line on the clear plastic part and free handing it sufficient?
What is the preferred way to use it to assemble a simple butted tenoned frame, say from 2" wide lumber, 3/4" thick? Specifically, what works best to register the tool on the lumber so the mating parts mate perfectly? Can it in fact be used "free hand with the target lines on the clear plastic part to align the machine to a scribe line? Or is it necessary to construct a jig to hold piece to be tenoned and align and fix the machine position? What works best?
Any tips on how to use this thing will be appreciated. So many have recommended it. I now have an opportunity to try it. If it doesn't work for my needs you will see it soon in the classified.
Re: Festool Domino question
Re:  Festool Domino question *LINK*
Jim Dillon
Bill, yes the manual that comes with the Domino is sketchy to say the least. See the link below for much better guidance. As everything is metric on the Domino, a 6-inch metric ruler is handy to measure the thickness of the wood. I also have a battery powered caliper that I use a lot in metric mode.
"Specifically, what is done to ensure the mating parts line up? Is using the aiming line on the clear plastic part and free handing it sufficient?"
Provided your Domino hasn't been damaged or the plastic guide moved, you can just use it freehand. Procedures for calibrating the scribe line are given in the links below.
"Specifically, what works best to register the tool on the lumber so the mating parts mate perfectly? Can it in fact be used "free hand with the target lines on the clear plastic part to align the machine to a scribe line? Or is it necessary to construct a jig to hold piece to be tenoned and align and fix the machine position? What works best?"
The Domino is so accurate that you indeed can just use the scribe line on the clear plastic part to hand-hold the Domino while you are routing the mortise. You will need to hold down the piece to be mortised somehow which sometimes takes me longer to figure out than routing the mortise. Laying out the mortise location often takes more time that actually cutting the mortise - at least in my hands.
Tip: Make sure you work from only one side of the wood. I usually just put a chalk mark on all the "face" sides. This avoids any slight errors due to setting the placement of the mortise. Have a scrap piece of wood handy to check the placement of the mortise. I find this to be the most time consuming in setting up the Domino.
"Any tips on how to use this thing will be appreciated. So many have recommended it. I now have an opportunity to try it. If it doesn't work for my needs you will see it soon in the classified."
Tip: Make sure you hook up a shop-vac to the Domino to pull the chips out. Try to use a balanced approach when holding the Domino - that is, holding down on the front and rear evenly. Also, don't rush the mortise cutting by pushing the Domino rapidly into the wood as this might jar the Domino a bit. Each mortise only takes 1-2 seconds to cut. Use a slow, steady plunge.
The "zero" setting for the width of the mortise really makes a mortise that allows NO sidewise movement. I generally make a couple of mortises with the zero width setting, the the remainder with the next width setting. You could also adjust the width manually by just moving the Domino a tad away from the scribe line. I do this a lot rather than changing the width on the Domino itself.
I also have used the Domino, instead of a slot cutter, to make slots for ebony inlay in G&G style furniture. Super great for cutting the mortises for breadboards and allowing for expansion at the same time.
The Festool website has several great manuals. The Festool Supplemental Users Manual by Rick Christopherson is great, as is the article by Jerry Work "Getting the most From the Festool Domino Machine" Lots of YouTube videos as well.
Sometimes the Dominos fit just too tight or have swelled a tad due to humidity. Microwaving them a bit or simply sanding on a flat surface solves this problem. An oven bake at low temperature would probably accomplish the same thing.
Have fun and practice on scrap first to get the hang of the Domino.
Hope this helps. I'll probably think of more later. Jim
Festool Manuals
Easy there Boys! :-) *LINK*
Rick Christopherson
Easy there boys, on the sweeping generalizations. ;)
While it is true that the first generation Domino factory manuals sucked big time, the more common second generation manuals that most people encounter, used much of the content from my first generation to create their second generation.
Ya know...just in case someone with a 2nd gen manual is reading this and wondering. haha :D
But, at the same time Festool used my 1st gen to create their 2nd gen, I also created my 2nd gen manual. So my 2nd gen version applied to both old and new models together.
Because the Festool website isn't always up to date, I keep a repository of all of my manuals available in one place at the link below. These manuals were commissioned by Festool-USA, and I have manuals for most of their more complex tools.
http://www.waterfront-woods.com/festool/
found site and found guides
It took some searching (I'm inept at these things) but I found the place where manuals are hidden. I downloaded them and briefly scanned the text. Seems to be just what I was looking for. Now I need to practice.
You're welcome.  Have fun!
Domiplate
Bill, get yourself a Domiplate to to use with the Domino. This is a depth plate for 3/4" and 1/2" boards. It makes set up and reliability of fit much easier. It is worth the extra. It has been invaluable in my kitchen build.
https://www.senecawoodworking.com/products/domiplate-for-1-2-and-3-4-ply
Grant Smith
Hi Bill,
I acquired a Domino a couple years ago second hand, and while I like it, it sure left me wanting to be able to easily make larger loose tenons. While Festool makes a 700XL version that fills the bill, I kept staring at the DF-500 I already owned thinking there had to be a way.
Sure, you could dink around and figure it out, but you are left to then try to fit shop made stock in to the eyeballed mortises that result. We need standardization.
I found a web site that talks a great deal about the Domino. It is the work of a guy names Paul Marcel (sot sure of spelling). He has a series of Festool videos on Youtube under the name/channel Half-Inch Shy. I have spent some time learning from his extensive testing of different ways to use the tool in order to get the most out of it.
One of my very favorites is his crib sheet on how to make repeatable wider mortises so you can reliably fit shop made stock in them. I certainly would have eventually arrived at a similar idea, but life is really too short to do everything on your own. Anyway, it is very useful for smaller table aprons, etc. Best part is that it gets a person thinking about the many ways to expand on the concept.
I'd provide a link to the website, but apparently that is no longer an option here. If you search for "Festool DF-500 Domino Extra Wide Mortise Guide", you will find it easily.
Regards,
Grant in Iowa
William Duffield
Here's the link, Grant. If you can't post a link, it's probably because you have lost your profile. It probably still exists, but WoodCentral can't associate it with your name, which if you have reentered it, must be exactly the same as whatever you used when you created your profile.
Half Inch Shy Domino Review #1
William Duffield
For many Domino operations on 3/4" thick stock, I find that indexing off of my table saw (work face down), instead of off of the Domino fence (with the work face up), is sufficiently accurate. It has some advantages: You often don't have to clamp the work. Also, there is less chance you will tilt the jointer and make your mortise crooked. While you can line up your mortises with pencil marks on the top surface of your work, if you are making a frame, the locating pins protruding from the front face of the Domino work very effectively for alignment. You use one pin at a time: one for alignment to the end of the rail and the opposite pin for alignment to the out facing side of the stile. If you have the DF700XL or the original DF500, the pins are spring loaded and retract, so you can set both at the same time, instead of selectively retracting and extending them for each plunge.
TomD
Bill is always reminding us about the fact that he doesn't do Youtube. I wonder if there would be any point downloading some stuff and posting it to him on a dongle. There is this new stuff on the Domino, but if there is any way to figure out the best stuff he has been missing, and jam it on the same drive, it might be worth it. It doesn't take long to download youtube videos.
