OT HP printer problem???
I have an HP desk top printer paired with an HP All in One Desk jet Printer/fax/scanner/copier. They are about eight or ten years old and have always worked well together.
Today the printer went south on me. I was working with Turbo Tax and had to print out a form. I have done the same form about three times in the last day or two. Today it failed to print properly. It failed to print the title and printed about every fourth or fifth line. It would print half of some lines.
I tried turning it off, unplugging it and restarting the computer.
I also went to a county website and printing some real estate documents. Same thing.
Any suggestions?
Re: OT HP printer problem???
JAMES FOLLETTE
Possibly the driver got corrupted. Go to the HP website and download the appropriate driver for your printer.
Jim Smith
Hello, Sounds like your print head needs cleaning, look in manual for directions usually can be found on HP website if you don't have one. Jim
John McGaw
Suggestion: there is generally a method available in the maker's software (not the computer operating system's 'print test page' option) to print a test image which is designed to show up any problems with the printing firmware and mechanism. Using this tool is usually the first best thing to do. If the gaps are as big as you suggest then a clogged print head is probably not the culprit since that usually only causes the drop of single rows of dots from the image. Have you changed anything in the way of drivers or software recently? Microsoft sent out a bogus driver update a few days ago which has caused problems for some people; you didn't install that did you?
my guess print heads need cleaning
Not a print head problem.....
Its some kind of a print format problem....
Just spent an hour and a half downloading new drivers from HP. Ran into every problem they could think of. Disconnect it, reconnect it, install new ink, uninstall, reinstall, uninstall the reinstall. Got to the end and they congratulated me on a job well done.....but no improvement.
I am wondering if the problem could be in the black ink. I just installed a new black cartridge. Why would that cause whole inch wide stripes of stuff to be missing?
I'll cogitate on this and get on with my day.
Re: Not a print head problem.....
Tony Memphis
i have had some weird issues that were attributed to the cartridges. I just replaced our ten year old with a new model. I like the wireless option and the printer seems to work real well. Has lots of stuff I'll never use, but it is nice. It has a touch screen! Why? I dunno.
Perfect timing eh? Tax season! Ha!
Tony
Stuart Johnson
My wife's HP has a problem accepting generic or refilled cartridges that will range from skipped print to way off color. At the amount they charge for cartridges and no longer than they last I don't know why they don't just give free printer with every second set.
Rethinking.....
I just realized its mostly the black that's missing. This printer has a habit of bitching about the color cartridges, which I don't use very often. Sadly, if it has a problem with any color cartridge it will not print in black. It asked for a new red(ish) cartridge and at the same time said I would have to replace the black cartridge soon. Being in the middle of tax season, I replaced both.
Later I began to experience trouble with the black. Skipping, gray, faint whatever. This morning I took a couple of printouts to a Geek and they think its the black print head/cartridge. Said to return the new black cartridge and try a new new one. And to clean the print head. I will try that when I get home. (Also said they have a lot of trouble with cartridges being bad from the git go.
The other way around...
Jerry Nicholson
When you run out of ink you buy a new printer. With the new printer you get a whole new set of (low capacity) ink cartridges. Kind of like when your cordless drill batteries go bad. Typically, a new drill with a new set of batteries costs only a little more than replacement batteries.
Re: Rethinking.....
Jerry Nicholson
I don't know what model of HP printer you have but on the older ones the print head is built into the ink cartridge. So no separate print head to clean.
Jerry
Re: Rethinking.....
Joseph Mulherin
I have the 1010 model of HP and have decided to buy and use CompandSave ink cartridges. They cost less and do a very good job on all my printing jobs.
You got that right.....
I Paid $83 for a oversize cartridge for this printer. Found out today I can buy a whole new printer for less than $100.
Fixed for now, I think???
After the geek in the store told me they had sold a lot of bad cartridges, I came home and installed a new cartridge. That helped. Then I cleaned the printheads and aligned them about three times. Its pretty much well. This was its last chance.
There is a new printer in my future.
Ralph Lipeles
My HP Office Jet does that sometimes when I use a non HP ink cartridge.
