200+ woodworking book reviews
Question about powermatic planer *LINK*
terry quiram
I have one of these on order and would like to know the size of the base. I intend to put a mobility kit under it and would like to have it ready.
Powermatic
Re: Question about powermatic planer *LINK*
Stuart Johnson
The one-piece welded steel stand has built-in lockable casters for easy movement around the shop.
I can't answer your question but why buy a mobility kit?
terry quiram
The wheels are not casters. As the salesman said it moved north and south but not east and west.
Well crap, I just downloaded the manual and found the answer to my question.
Matt
I have this planer with the helical head and it moves fairly easily across a concrete floor with the provided wheels. It has "handles" under the tables that allow you to grasp for steering east-west and push/pull north-south.
I have the 20" version. It rolls forward and backward easily. It does not pivot but I just shove the the thing the direction I want. It doesn't take much effort. T.
William Duffield
Mine leaves black streaks all over the shop floor whenever I want it to go in any direction it doesn't want to go. Also, the wheels it comes with are not level, and it wobbles when I don't want it to go anywhere.
Partial Hijack - Tell us how well it works
Stephen F Roth
I am looking the same exact unit to replace my Dewalt 735, in which I have installed a replacement Byrd Helical head. The main reason I'm replacing the Dewalt is because of the cutting depth. (It strains at anything close to 1/16 at full width.)
My concern about the Powermatic is how good the final surface is. My dealer (a very honest guy), says I would probably be unsatisfied with the final finish of the Powermatic compared to the Dewalt with the Byrd head, and I should keep both around -- Powermatic for depth and Dewalt for finish. But I don't have the room for both, so if I could only have one, would stay with the Dewalt and just make more passes.
It seems to me that they both end up with the same cutters hitting wood. But the dealer said the cutting speed of the Dewalt ends up with a cleaner cut.
Hope you can share your experience. Good luck with the new tool.
Re: Partial Hijack - Tell us how well it works
Matt
Your dealer is correct. From my experience, the 15HH is great for faster, more powerful planing but my previous bench top planer with sharp blades left a smoother surface.
I prefer the 15HH over a smaller machine but you do have to deal with roller/feeder marks (some times) and more snipe, but this is all part of dimensioning the lumber and then continuing with other tools to complete the work.
