Saved Some Shellac
Saved Some Shellac
Saved Some Shellac
My stock of Ultra Pale dewaxed shellac flakes was getting old, and it's currently hard to get, so I decided to mix anyway. I could always hope.
Powdered the flakes in the chopper-ina-hopper then mixed a pint of dried DNA to see what I could salvage. Agitated regularly and then sat over night. The morning light showed a significant amount of undissolved stuff in the jar; not auspicious.
I decided to proceed anyway and ran the mix through a "Bounty filter." Took 4 sheets as the paper towels kept clogging with the rubbery bits. I then refiltered it through a couple of coffee filters. Mix came out very clear and netted a bit over 14 oz. of liquid.
Applied the double filtered mix to some wood and a piece of glass.
Next morning the shellac application powered nicely on both surfaces!
I'll now use it on the seal/tie coat phase of finishing my G&G Bandini Bench.
Dry shellac flakes do have a shelf life. For those here who mix their own, filtering the mix will improve your results and may (but might not) help you get a bit more use out of your stock. This batch of flakes is 3+ years old and is the last of several pounds I bought from Homestead.
Re: Saved Some Shellac
Dried DNA?
Dick Coers
Makes me shudder, but have to ask? Huh?
Re: Dried DNA
We had a thread about this a while ago. Bill T. disagreed with me regarding the water content in commonly available DNA. However, I was having an issue with mild grain-raising when applying shop-mixed shellac to wood surfaces.
After a bit of research I stumbled upon a discovery that's used to remove the residual water content in ethanol after distillation. The "process" uses tapioca (yeah, the pudding stuff) which, when added to the alcohol, absorbs the water and gets the alcohol down to something very close to "anhydrous" or water-free alcohol required for motor fuels etc. You then draw off the "dried" alcohol and spread the tapioca, which doesn't absorb alcohol, out to dry. The tapioca can be reused many times over.
Therefore, figuring my grain-raising issue must be caused by water content in the DNA, I bought a bag of tapioca at the food store and gave it a shot.
I put 18oz of alcohol in a jar and added a cup of the dry tapioca. Shook it up occasionally and let it sit overnight. Next morning I poured off the DNA and used it to mix my shellac. I applied the mix to a cherry surface sanded to 150 and vacuumed off well.
Eureka!! No raised grain on the cherry. Tried it on walnut, same result. Problem solved!!! :) :)
While I don't bother processing all the DNA I use, for my shellac mixing its now s.o.p.
Wow!  Neat!
Tony Memphis
That is very interesting! Neat trick.
Re: Dried DNA
Wow, great idea!
An opposite trick is to add a little water to alcohol then use that on wood. It will raise the grain for sanding but still dry a lot quicker than straight water. I saw a woodturner do this a long time ago but I can't remember who.
Good Tip!
And here I was...
John in NM
With images of you dipping into the priceless stash of Wooly Mammoth Powder :D
I even coined a new nickname (Jurassic Mark) before the sensible part of the brain kicked in and came up with "denatured alcohol" :D
There You Was
in the wrong epoch. [hint - Pleistocene . . . too hard to rhyme, even for Shirley]
I do, however, have a T-Rex album ["prang!"].
:D :D
Yeah, should know better...
John in NM
I had them all memorized in college, but the shiny rocks made me quickly forget all the dead stuff classes :D
Our geology club did have an annual party to watch the movie Tremors, all because it contained the phrase "pleistocene alluvials" :D
John in Lutz
In your email you stated that Shellac is now hard to get. I routine buy from the Shellac Shack. Just last week I bought Platina Dewaxed which is a very pale shellac sounds similar to what you were using.
Thanks!
I'll look'em up
Hmmm, Thought Those
were "Precambrian Lifeforms" . . . ;)
Re: Hmmm, Thought Those
John in NM
The science in that movie was even sketchier than in "Contact" :D
Sketchy
With 80% of the planet's history open for their "use" of the term, the creators had a pretty wide time frame to draw from.
Not really
John in NM
There's no fossil evidence that I know of for land based life forms before mid-late Cambrian period, which means about 88% of the earth's history would be off limits :D
Don't even get me started on "Contact"! :D
Hollywood and science just don't mix.
Re: Not really
Paul in NJ
Hollywood and most things don't mix.
Re: Not really
Jesse Cloud
Not Hollywood, but one of my favorite memories from my comic book fueled childhood/adolescence was a scenario in Superman. He was attending to business on another planet, but saw that Earth was in jeopardy, leading him to "fly back to Earth faster than a trillion laser beams." ;) :D
Hummm,,,,, no mention of
Keith Newton
thrust faults along orogenous zones? ha
I've got a geologist friend, former prof that told me about a female student who confronted him after a class for talking dirty in a class. ha
Drying Alcohol
Another alternative is to put molecular sieves in the DNA.
say what?
"Bill T. disagreed with me regarding the water content in commonly available DNA."
I did a chemical analysis for water in my can which yielded a result of 3.6%, compared to the estimated value of 3% based upon a typical composition of store bought "alcohol". Evaporation and cooling could drive the surface concentration on the wood higher by condensation. What was the disagreement?
perfect agreement
I stated from theory of how this stuff is made and purified that the water level would be between 5%, the concentration of water in ethanol derived by distillation from a fermentation, and 0% for methanol, and ethanol derived synthetically from ethane (gas wells). I found 3.6%. perfect agreement.
It is interesting that tapioca can suck up water from alcohol. I need to look into what is going on there. I expect some sugar compound is doing the sucking.
No, it's starch.
"I expect some sugar compound is doing the sucking. "
I expected a Polysaccharide but Tapioca is pure starch, a closely related compound. Starch absorbs water and the pellets of tapioca are a handy form to administer the starch in. I am surprised that it works as well as reported. I'll see if I can get a water measurement in alcohol after this treatment.
