Table Saw Drive Belts
Yonak
I'm having a difficult time finding matched belts for my Jet JTAS-10L table saw. I've gotten three sets and, with all of them, one belt is either too large or too small. Does anyone know of a supplier from whom I can get good truly matched belts ? This saw takes three belts.
Re: Table Saw Drive Belts
Re: Table Saw Drive Belts *LINK*
Bob Entwisle in NJ
I've no experience with em, but this link is to a PDF for Browning Belts, and indicates that they will match belts etc. Maybe give Regal parts a call and ask.
http://www.regalpts.com/PowerTransmissionSolutions/Other/Belt%20Drive%20Monthly's/Form_9787E.pdf
Link to Regal parts,
http://www.regalpts.com/Pages/home.aspx
Let us know how you make out, my unisaw will need new belts someday.
Bob in NJ
Belt Matching
Clementine
I went to a link belt on my table saw and drill press. It solved several issues. I don't know if link belts would work in a multiple requirement. Maybe someone on here can answer that.
Lee Schierer in McKean, PA
Gates V80 series belts will match length.
Lee
Absaloootly
I've had Fenner (red link-belt) drives on the same JET saw for over 12 years. They are smooth, quite, and matched precisely.
The only thing to watch is to make sure that the little direction arrows printed on the links are oriented in the proper direction.
BTW, I use them on my band saw, jointer, and drill press as well.
Re: Absaloootly
Yonak
Mark, do link belts have to be matched or, since they are not rigid, simply the same size would work ?
I have never used link belts (my machinist friend also recommended I use them). Have you ever noticed them slipping ? I'm sure there's a tutorial on-line on how to tension them.
Yonak
John, I imagine this method would cut down on vibration. It seems to me, with the tight quarters, however, I would likely have to remove the table to install this type of belt. Thanks for the suggestion.
Thanks for the links, Bob.
Count
links and they match; simple.
I have never stalled the blade on my saw. Not that I haven't tried you understand ;)
I would suggest, however, that before you install the new drives, you clean both of your sheaves.
I tensioned my belts with a piece of 3/4" rebar as close to the center of the belt loops as I could get. Provided your sheaves are parallel, tension on the 3 belts will be the same. Just for whatever, after about an hour's run time I re-tensioned them. Haven't touched'em since.
Re: Count
Yonak
Great, thanks, Mark. I'll order some belts tomorrow.
Go to a power transmission store
Pete in Holland MI
Order up "matched" belts from a "power transmission" store. Special care is taken for these belts. Belts from the local hardware store will have a degree of variation, as cost is key here.
Pete
