Wood finishing
Wood finishing
Wood finishing
Howardd
I'm building a small cabinet out of Baltic birch and want to finish with a white enamal. What would be the best primer to use water base, oil base or shellac base?
I hate finishing and need the most fool proof primer.
Thanks
Howard
Re: Wood finishing
Re: Wood finishing
Dewaxed shellac.
Either mix fresh from dry flakes (best) or use Zinnser's SealCoat
Re: Wood finishing
Re: Wood finishing
I use Kilz under paint. It can be sanded glass smooth then painted.
Re: Wood finishing
Re: Wood finishing
Shellac is good for sealer, ineffective for filling. A high solids primer like Kilz will fill in all the pores and leave a glass smooth surface. If I wasn't striving for smooth I would not seal at all....just paint it with paint.
Re: Wood finishing
Re: Wood
Howard's working with baltic birch so I don't see the need for pore filling. It appears that he will be hand applying. Kilz will be more work to level and remove brush marks that a light application of shellac.
Re: Wood finishing
Depends on the quality of the plywood
Dick Coers
I've seen good Baltic birch plywood, and I've seen cheap import stock that is as rough as a cob. The rough stuff would benefit greatly from a heavy bodied primer.
Re: Wood finishing
That depends a lot on you,
Keith Newton
and how you intend to apply it. Will you be spraying, and if not what, roller, brush, or corn shuck?
Re: Wood finishing
Guess I'm Spoiled
The only BB I've seen looked to have been sanded to 180.
Re: Wood finishing
good point....
"Kilz will be more work to level and remove brush marks " The solvent based Kilz needs thinning to flow well. But it sands easily to glass smooth.
Re: Wood finishing
Re: That depends a lot on you,
Howardd
I will be using a roller
Re: Wood finishing
Re: Wood finishing
TomD
I've used Behr super white Int/Ext over plywood, and other paint grade wood, and I use the Behr primer. It delivers results almost as good as a gloss enamel, and it is easy and safer to work with. I use it on my boat also. I have it right net to plywood that was shot with alwgrip automotive paint and it looks the same and lasts longer. I wouldn't paint my car with it, though. :)
This is all in awlgrip except where I had to make repairs. The boat and trailer are all wood and mostly plywood.
And this is after I painted parts that needed it in white Behr latex. Obviously you can't tell, but frankly, I figured you could tell even from a photo, or a distance. I can't today tell which were painted with which. Except there are some areas that haven't been touched.
