Breaking down plywood sheets
I don't work much sheet goods or I would have a better way of handling them. I can rip 4 x 8 to what ever is needed but my fence only goes to 26". I was recently faced with dividing a 4 x 8 approximately into two 4 x 4 pieces. It is for the back of the display cabinet. What to do? I am useless with a "skill saw" and I feared a skill saw blade would splinter veneered plywood. I knew a hand saw would splinter the veneer.
I tried the saber saw with a 20 tpi blade. I have found that as my hand tool skills improved this experience translated to power tools. I was able to split the pencil line I made to divide the sheet. And, the cut was splinter-free. I cut from the back side but probably didn't need to. I must file away this technique for future use.
Re: Breaking down plywood sheets
Yonak
Bill, don't forget the usefulness of a fence for good, straight, easy cuts with, either, a Skil saw or a sabre saw.
Bill Howatt
The thing I can takeaway with thanks from your description is using a saber saw with a 20 TPI blade. My line-splitting, straight cutting is totally inadequate and perhaps I should do more hand tool work.
For this type of problem I use the skil-saw with on a piece of ply with a straight edge located on it such that the blade runs down the edge of the ply for easy and accurate location of the cut. However, the splintering can be an issue so by making a larger shoe for my saber saw to fit my guide and using a 20TPI blade this may work for me when needed.
Thanks for posting and I admire your straight line cutting.
Bill
fences
When I have assumed the employment of fences to be a foolproof means to a straight and accurately positioned cut I have often been fooled. But, for those that have good experience with straight edge guides, your point is well taken.
I worked a bit in a shop with an experienced cabinet maker that worked a lot of sheet goods. He got me confident solo ripping full sheets on a table saw. He would cross cut sheets free-hand. I don't have the confidence to do that.
John McGaw
I guess that 'whatever works for you' applies here. I've found that using a 6-1/2" 40T Freud in my DeWalt battery-powered saw does an excellent job and does not splinter anything I've tried it on. Breaking down sheetgoods is important to be since my shop is miniscule and moving my half-ton Robland around, even on wheels, to handle big sheets is no fun at all. I have gone so far as to break down the sheetgoods and over-length stock in the parking lot of the supplier using whatever is at hand (including a chainsaw on a couple of occasions at the sawmill). I much prefer to have the option of breaking down to 'close enough' tolerances but with a straightedge I can usually split the line on sheetgoods when using the DeWalt.
Lee Schierer in McKean, PA
Since you have a Bosch jig saw, try the Bosch T-234X blades on your plywood for a superior cut quality.
Lee
My approach with a guide PICS
Tim Greif - West of Chicago
Factory edge on a piece of plywood screwed to a piece of hardboard. Cut the hardboard slightly wider than the saw base, then rip it to size after attaching. You now have a zero clearance guide that pretty much eliminates chipout. I still cut with the good side down, but it reduces chipout enough that I have successfully cut melamine with very little problems. I use a 60 tooth blade.
Re: Track Saw
Hank Knight
Bill,
I use a fair amount of sheet goods. My shop is tiny and breaking down 4X8 or 5X5 sheets there is difficult and very awkward. I got a great deal on a Festool track saw and, with a couple of sawhorses in my driveway, my problem was solved. The track is designed to provide a perfect saw line and it clamps to the workpiece, so you get perfect cuts every time. It is absolutely as accurate as my tablesaw. It's way better than trying to follow a pencil line with a circular saw or a jigsaw, with or without a fence. If you see more sheet goods in your future, you might want to check out track saws.
Hank
Re: Track Saw
james runchey
I use, as I have for at least 30 years, the home-made straight edge method as related by Tim. I have a 4 footer, as well as an 8 footer. Works like a charm every time using my worm-drive Skilsaw, I have never had a slip veering off the line. It's just as accurate as my tablesaw.
Now that is a clever idea.
Have you submitted it to Pop. Woodowrking?
Re: My approach with a guide PICS
Ray Newman
More years ago then I now care to recall, I built a similar jig. Also built a similar one for router use.
Cut sheet goods with it and it worked very well. Worked even better after I purchased the now-discontinued Porter-cable 4 1/2" worm drive trim saw and a dedicated carbide blade for it. Very handy little saw. To prevent splinters/blow out, I ran a strip of masking tape on the cut top/bottom and 'nevva' had a problem. Only problem was making a less than 90 degree cut as the base never seemed to hold the desired angle. Sometimes I still with I had the saw as it was so light, handy, and easy to work with.
Firmly believe that a dedicated carbide blade and taping the cut will improve saw performance and cut quality.
I break down plywood sheets using either a 98" clamp guide or a 50" clamp guide and a Dewalt circular saw.
Dewalt (and others) make a 60 tooth blade in a 7 1/4" diameter that leaves a very smooth cut.
I have ripped (and crosscut) plywood with this blade without splintering the veneer. It has worked for red oak, poplar and maple plywood (as well as the Home Depot cabinet grade pine).
Bruce, a MN Galoot
I made one each for the Skilsaw and router, as you say, more years ago than I care to remember. They work very well. For the Skilsaw, I got a 40 tooth Freud, thin kerf carbide blade. It was really hard to find because my saw is a 6-1/2" model dating back to the early 1950's.
AZ in Colorado Springs
I've had a rig like that for about ten years, in 8' & 5' lengths. But if you make the bottom board a bit wider, you'll have more space for clamping it to the work piece.
Not new
David Yoho
Pop Wood, I'm sure, has seen that one. I got the idea from Glen Huey when he was there. I have four made up from 1/2" MDF and 1/4" hardboard for the four different width router bits I use to cut dadoes in plywood. I use a different guide for my circular saw to crosscut sheet goods.
Re: Track Saw
Hank Knight
James,
I agree, Tim's jig works very well and has the great advantage of being inexpensive. I built and used one for years, and would still be using it but for the deal I got on the track saw. (Festool came out with a new model. My dealer was unloading the old model and sold one to me cheap.) I found with Tim's jig, it was possible to let the saw creep away from the fence and ruin an expensive piece of plywood. If there's a way to screw something up, I'll find it! The track saw has the advantage, for me at least, of locking the saw base into the track so it can't get away from the fence. Sure, it's a lot of money to pay for one small advantage, but I like it and thought I would mention the tack saw option in response to Bill's post.
Hank
another advantage- dust collection
Joseph Piotrowski
after seeing a festool and how collects dust, especially on plywood. i want one badly! after wadding into the electron free world, my tolerance for the dust created by my power tools is becoming an issue. so much so that i don't even want to turn them on!
soon as i stop buying hand tools, this is next.
my experience too
"I found with Tim's jig, it was possible to let the saw creep away from the fence"
This is the same experience I had with my rare use of a fence. Probably would not be the case if I used a fence more often, but I don't have the need. As well, I would experience some unexpected variable, like a change in saw blade or whatever that affected the offset of fence to kerf. I'm just prone to being fooled by the fool-proof in most aspects of woodworking.
Before I saw someone do it I thought it impossible to split a scribe line sawing dovetails. There have been a great deal of things in woodworking that I thought impossible before being shown they were not. Once the mental barrier of thinking something impossible was removed by demonstration I found that with a little practice I could do it too. So it was with splitting a pencil line, wider than a scribe line, free-hand with the saber saw. It just took concentration. I'll never bother dealing with a fence again to cleave a piece of plywood.
Track Saw
Brian Holcombe
A couple have mentioned, and I will as well. A track saw is wonderful for this and general straight line ripping within the price range of the average small shop.
I have one, along with it the dust collection unit, and it collects a great majority of the dust to the point that the dust that it doesn't collect is hardly noticed until I move the wood.
I use this not only for plywood (which is rare for me at current) but for material up to 8/4.
It was much easier to break down rough 2" thick (9/4~) mahogany using a track saw than I would assume it to be on anything requiring the use of a reference edge (like a table saw).
james runchey
Someone mentioned a problem with saw creeping away from the guide. I never had this problem as I used both hands on the cut, right hand on the saw handle, and left hand on pinched on the sawfront, forcing it against the fence.
