Koa
Larry
Looking for Koa 1/16 x 3 x 22, for building a Ukulele .
Thanks
Koa
Larry
Thanks
Re: Koa
William Duffield
Have you tried Woodfinder? I see 10 suppliers for koa in California, including McBeath in three locations in central CA.
Re: Koa
TomD
Are you saying you need that predigested, or you need to get the base stock. Most wood for Ukes, and guitars and such comes thicker than that to be reduced to personal preference. If you buy the wood pre-thinned, it costs more, and it can distort in areas of high figure, where that wouldn't happen if you went straight to bending and building.
I used to have a drum sander, but now I hand plane the sides, or use my planer. To use a planer, it depends somewhat on you planer, I glue the sides together than flip them through the planer, they remain stiff enough to plane very thin, as my planer will go to 1/8", so 1/16" is possible without hand planing. However, it will chew up some woods. Routers can also be used to thin guitar stock, but I won't go there unless asked. For Uke sides, they are often so narrow that they can be thinned using standard drums on a drill press.
You should be able to get Koa from ebay, LMII, maybe Stewart Macdonald, also there are some Island based Uke shops that sell materials. Many wood stores sell it if you have the means to reduce it.
Re: Koa
Larry
I do have several feet of 4/4 Koa, guess I will try cutting some down .
Re: Koa
philip f Duffy
Try-- Colonial Tonewoods---, a company that specializes in supplying woods to some of the great instrument workers/builders in the world. It is run by Steve Roberson, a good friend and neighbor here in VA
