Progress shot
Progress shot
Progress shot
Here's the latest shot of my current vanity project. The wood is solid Burmese narra (Pterocarpus indicus. The drawer bodies are Alaskan yellow cedar, running on ipe rails. The cabinet is prefinished birch plywood. It will have a granite top with two oval undermount sinks. I still haven't come up with a drawer pull design.
Narra is my favorite wood, or certainly one of them. It planes beautifully (with sharp planes, of course) and takes a lovely polish. It also doesn't darken the way its cousin Padauk does. I've been saving this lumber for over 30 years. I figured use it or lose it.
Cheers,
Re: Progress shot
Re: Progress shot
Keith Newton
Looking good Ellis. Is that front bowed, or is that from a wide angle lense?
Re: Progress shot
Re: Progress shot
Andy Lincoln, in Dearborn Mi
Wow,
That is a great cabinet and a great piece of wood from your stash. I'm glad it found a purpose.
Re: Progress shot
rail choice question
As I understand it Ipe is loaded with silica, or can be. I know it mowed off the edge of my jointer knives the first (only) time I used it. Could this situation be like running drawers on sand paper?
I use maple runners. A hand planed waxed maple surface glides drawers effortlessly. It is hard and non-porous so abrasive junk doesn't stick in it.
Re: Progress shot
Ipe
Ipe is indeed hard on tools. I've even burned out carbide tipped router bits with the stuff. But, once polished and waxed, it's more like marble. No abrasion worries as far as I know. I hope I live long enough to wear out my drawer sides. :)
Re: Progress shot
Re: Progress shot
The front bows out about 3". I wasn't crazy about ripping up 10" wide boards to make staves, but that was the only sane way to construct those doors. One of the boards had a section of crotch at one end, so I saved that for the drawer fronts.
Re: Progress shot
Re: Progress shot
Joseph Piotrowski
that is one fine looking vanity. some of that wood i never even seen before!
Re: Progress shot
Re: Progress shot
Stuart Hough
Outstanding piece of work, Ellis!
Re: Progress shot
Kneale Brownson
Stunning wood, Ellis
Kneale Brownson
I'd use small white ceramic pulls.
Re: Progress shot
Re: Progress shot
JAMES FOLLETTE
Great use of beautiful wood, great woodworking. Ellis, you've still got it!
Re: Progress shot
Is the logic sound
"Could using Ipe for runners be like running drawers on sand paper" Your use of Ipe for runners will be a strong recommendation to many, in situations differing greatly from the vanity. The question is directed to using Ipe runners on furniture with a long anticipated service life. Globally, the question is what is the best wood to use?
Waxed, the drawer would be running on wax, so it doesn't matter. But waxing can not be relied on for some(most?) furniture. The first and last time it will be waxed is when it leaves the shop. What wood will yield the least abrasive surface for a drawer side, and be more resistant to abrasion than a drawer side? Does the effect the wood has on dulling tools have any bearing on this question?
Re: Progress shot
Pulls?
Oh Ellis, that is one fine piece! Beautiful wood and used very well. My only thought is about using pulls. The piece, as shown, has such beauty that I would be concerned about pulls distracting or interrupting the flow of the wood through the drawers. Maybe you could shave a little off each drawer front bottom and attach a thin ebony strip(the length of the drawer front) that curves outward to provide a grab? Just a thought. But still....very cool work!
T.
Re: Progress shot
Logic
Bill, I don't consider ipe abrasive enough to cause premature damage to the drawer sides. And, regardless of its abrasiveness, I admit that it is denser than necessary. My rule of thumb for drawer runners is that they should be harder than the drawers that run on them, because it's generally easier to repair a worn drawer side/slip than a runner. In this case, the ipe is in the form of strips screwed to the inside of the cabinet, so it would be a snap to replace.
So, you've made a good point. Maple would be plenty hard enough and equally slick. I still don't think that ipe is likely to ruin these drawers, at least not in my lifetime.
Re: Progress shot
Re: Is the logic sound
William Duffield
Good questions, Bill. I don't know the answers, and the FPL doesn't provide abrasion resistance measurements for wood species (or for grain orientation, which might also be important). At least, strong design criteria should be that both the runners and the bottom edges of the drawer sides are as easily repairable as you can design them.
Another factor is what materials are available in your shop: It would be difficult to source or to convince most customers to pay for lignum vitae runners and drawer sides, even if they might last five centuries. :)
Re: Progress shot
vertical stave doors
Gary Smyth
For the next update could you provide a picture of the open doors? With two under mount sinks I'm not getting a mental picture of how the doors open and the plumbing path. Do all seven staves form the door or maybe four or five on each side? I take it that the hinges are European style with a over 90 degree open angle.
Re: Progress shot
Re: Questions on Design
William Duffield
That's some gorgeous wood. How did you decide the vertical proportions of the drawers? Starting at the top, I measure 8:10:9:9:10, which to my eye is a little incongruous.
Looking at your previously posted picture of the cabinet carcass without the doors installed,
I can see that the seven vertical boards on each side will cover a singe large opening. If they are single doors, they appear to be quite wide, which would require a lot of open floor space in front of the cabinet. Are they single or double (asymmetric) doors? Is the construction board and batten, or something more sophisticated? I notice that the vertical boards in my board and batten kitchen cabinet and closet doors have slipped over the years, and are no longer square, with slightly serrated or stepped top and bottom edges.
Re: Progress shot
Some data
...but again I don't know if it is relevant. Decades ago, literally, a plastic idler pulley broke on the drier. It idled the belt that turns the drum. To get it going I quick turned an idler pulley from a piece of maple, with the best of intentions that I would replace the pulley later. Well I forgot it. I was reminded more than 20 years later when we moved which is twenty more years ago. This piece of wood has turned on a steel shaft for a bizzilion hours with little wear to wood or steel.
Silica containing wood has silica particles embedded in the wood. I have seen photomicrographs of these particles. It these particles wear away at steel rubbing against it I am going to presume they will show accelerated wear at wood sliding over it.
I made a plane from Ipe. It is exceptionally stable. Maybe I am "sanding" as I plane :)
Re: Progress shot
Re: Pulls?
Thanks, Tommy. Yeah, I haven't made pulls yet because I had the same concerns that you mentioned. Still cogitatin' on it. Your idea sounds interesting -- worth some consideration....
Re: Progress shot
Re: vertical stave doors
Here are a couple more shots, Gary. Each door is six staves, hung on 120º Euro hinges. This vanity goes into a large bathroom that has plenty of room to open the doors.
Each compartment has hot and cold feeds and a 2" drain.
Re: Progress shot
Hi Wm,
Drawer heights are (1) 4.75", (3) 5.75" and (1) 6.5". So, that second drawer only looks bigger than the two below it. Still, I can see how the illlusion can be unflattering. Oh well. I didn't resort to a Fibonacci sequence or anything like that. I wanted the top drawer to be of a certain inside depth and the rest of the boxes to be identical in height, which makes the bottom drawer front 3/4" higher than the previous three.
I'm planning to add a Z-brace in each door to keep the boards from sagging. Originally, it was going to be a simple slab of wood with a long shoulder on each of the battens to keep them square. That would be something I could hang something on. For now, I just need to get my dust collector fixed and get on with the program.
Re: Progress shot
Hank Knight
My previous post on this stirred little comment, but it might fit better in this thread. I found a solution for those worried about abrasion of drawer sides and runners, especially where the drawers are heavily loaded. I built drawers for a drill press stand that my father started years ago but never completed. He installed oak runners. My drawer sides are poplar. Because of the weight the drawers would carry with drill bits, vises and all the other paraphernalia that goes along with drill presses, I was worried about rapid wear of my poplar sides. I solved the problem by supplementing the bottom edge of the drawer side with a strip of 1/4" UHMWPE. I roughed up the glue surface of the UHMW with coarse sandpaper and glued it to the bottom edge of the drawer side with West Systems epoxy. This is not a strong glue joint because glue does not adhere well to UHMW; so, after the epoxy cured, I screwed the UHMW strips down with flathead screws countersunk well below the surface. The result is a very slick surface on which the drawers ride. There is very little friction between the drawer side and the runners, so the heavily loaded drawers slide with little effort. Best of all, there is no noticeable wear on either the runners or the sides after 3 years of regular use. Here's a couple of photos:
[URL=http://s50.photobucket.com/user/hankknight/media/Workshop/image_zps36166b37.jpg.html][/URL]
[URL=http://s50.photobucket.com/user/hankknight/media/Workshop/image_zps44f3fc52.jpg.html][/URL]
Re: Progress shot
Dryer repair...
John in NM
Bill, that is priceless :D Best part is your maple pulley has likely outlasted a replacement plastic one! Last plastic pulley I broke was on a power steering pump... I wish I'd thought of a wood one! (no not entirely serious on that one :D )
Re: Progress shot
Re: Progress shot
Mark Hennebury
Nice job Ellis! really nice and clean lines.
Re: Progress shot
Mark Hennebury
I guess if you were going for the ultimate drawer runner, probably Lignum Vitae would be right up there.
Re: Progress shot
Solution noted
I am wondering if the stick on sheets stuck on the runners would be an easier solution. I solved the problem of heavy lathe stuff in drawers with Accuride 75 pound runners but your solution is cheaper. Those strips would make dandy runners for saw sleds.
