Tenon maker
Tenon maker
Tenon maker
I have had problems making precise tenons for as long as I have built stuff. For the display case I needed some long ones for the side rails. Fine Woodworking just had a description of a tenon maker using a router template. As much as I hate taking the time to make jigs I made this one. The result was 6" long tenons (to be divided in two portions ) that varied less then 0.002" along the length. I was delighted.
I chopped the mortises with a chisel.
Re: Tenon maker
Re: Tenon maker
Bill, I have been learning to work with loose tenons and have Made a couple of jigs.
I like yours. If you anticipated using it a lot would it be better to use something like a trip of aluminum for the guide bar?
Have you considered making one to cut the mortise? If the tenon is 3/8", make a slot the width of your guide bushing and put a spiral up-cut bit in the router and position the jig and cut mortise.
Re: Tenon maker
Re: Tenon maker
If you anticipated using it a lot would it be better to use something like a trip of aluminum for the guide bar? I'll never wear the wood out and it is trivial to make anyway.
"Have you considered making one to cut the mortise?" No. I do not have a plunge router. I can chop a mortise fairly quick with a chisel.
Re: Tenon maker
Alternatives
After years of sawing tenons by hand, I just freehand them now, and clean up with a chisel when necessary. My main alternative to this is to use the bandsaw. However, although the blade cuts straight, the bandsaw is less easy to align accurately. Plus, the tenon/mortice is rarely ever perfectly centred, which means one cannot simply flip the piece over and cut the other side of the cheek with the same set up. We need to work from a reference side for this reason.
Some years ago I created a handsaw guide for tenons. The objective was to help those with lesser hand skills or those wanting to develop hand memory towards working freehand.
The write up is here: http://www.inthewoodshop.com/ShopMadeTools/TenonGuide.html
The short version:
The jig ...
This has a sliding fence.
Place the stretcher under the fence ...
... and slide the saw plate up to the line. Saw the cheek, then reposition the fence for the other cheek ...
This really takes little time to do.
The jig also makes it easier to saw the shoulder lines ..
Re: Tenon maker
fancy!!
Joseph Piotrowski
that is a sweet jig. thanks for sharing. for an up coming project, it walks you though cutting briddle joints using saw guide. you have to make one for each cut. total of 4 jigs. this would be so much better1
“My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.”
one part of my brain go in the direction of adding more features, self clamping, index common depths. kerf blade adjustment. and on and on.
the other side that actually has to make it say keep it simple!
1. i think if you took 2 of the magnets and put then on the top of the fence, you wouldn't have to take it apart.
2. i think one runner is enough. middle only?
as a novice, of the desk jockey type and far less skilled in hand saw techniques, i think saw guides are invaluable to my kind. you should see see how i butchered some dovetails by hand.
Re: Tenon maker
Bandsaw them with a single reference face.
Brian Holcombe
If you flip them, they will not line up, but if you Bandsaw them from a single reference face they fit just like you would handsawing them.
I prefer to cut small tenons by hand, they're quick and easy, and big tenons by bandsaw using the single reference.
Re: Tenon maker
Re: Tenon maker
I have a heavy cast iron tenon jig for my table saw from Rockler. I tore it apart and reworked the jig, and preened the guide rail to fit the saw precisely. Then using an indicator, I mounted a .001 indicator on the jig and measured the blade alignment parallel to the jig (believe it or not my Delta Unisaw had less than .001 run-out). After that I found I can cut tenons to less than .001 variation, using the same face of the jig and stock and moving the jig with relation to the blade. Works well for me and actually doesn't take long to set up using a cutoff. I can consistently cut tenons to less than .001 variation. I then use my sled to cut the shoulders.
Re: Tenon maker
I do the same thing
Bruce, a MN Galoot
except my tenon jig is one I made years ago, using a plan published in FWW.
Still, I might try Bill's method. It would be nice to cut both the cheeks and shoulders at the same time.
Re: Tenon maker
Adam of Oakland
I read that article from the mag as well
Adam of Oakland
glad it worked well for you, Bill - I also liked how they applied wedges to angle the tenon/shoulder cuts, common in chair making. I hope to try this approach at some point whenever I can get around to making a chair or two.
-Adam of Oakland, CA, USA
Re: Tenon maker
Re: Tenon maker
TomD
I prefer using a router table. I waste the wood using a bandsaw and radial arm, or anything similar. All that remains is the precision facing of the last 1/16. And you can do that fast and accurately with the tenon flat on a router table. Less stress on the router, you can do huge tenons. It's the method used in the fww shaker table video. No jigs, though, if you don't have a table you can quickly make one as shown in the tape.
