Lobster meat?
Lobster meat?
Lobster meat?
Marc in Mass
Last Tuesday morn at about this time I underwent spinal surgery on a herniated disc(L4-L5) and they sent me home the next day. Doc says everything went well and the situation has improved. I'm up walking and took myself off the heavy meds Sat. Advil from here on out. Therapy starts in a week. Now, about the title of the post. A spinal disc is a weird substance. It has a texture similar to a scallop and, according to my doc, cooked lobster flesh. He said he took tweezer like tools and pulled off the protruding and nerve pinching portion of the disc to relieve the pressure. That and a bit of judicious vertebrae edge material removal gave the bulged disc material somewhere to retreat too. But, lobster meat? How tough is that? I imagine a lot of you all have had a similar operation and I guess I'm seeking more info about what to expect from actual recipients. (Like when I can get back into my shop).
Re: Lobster meat?
Just don't do what I did
Mike Farinella
Had almost the same surgery as you in 1994. In 2004, I was helping a guy lift a cabinet (over confident) that weighed over 200 lbs. Never been the same since. Be careful and think before you lift.
Re: Lobster meat?
Go Light
on the butter sauce
and the lifting. ;)
Oh, and Motrin may be more effective.
Heal well.
Re: Lobster meat?
Re: Go Light
William Duffield
Advil and Motrin are both ibuprofen. Difference is only important to corporate conglomerates and their advertising agencies and lawyers. :D
Re: Lobster meat?
One other difference...
John in NM
The dosage :D
IIRC, prescription Motrin is something like 3 Advil tablets.
Re: Lobster meat?
Re: One other difference...
I just looked it up....Advil, Motrin, Midol, NeoProfen, Caldolor, Profen, Select, are all Ibuprofin. The typical Over the counter version comes are a 200mg dose. The prescription dose is 800mg. I broke a rib and all they did for it was offer to write me a prescription. I said, never mind, I will take four of the OTC stuff if I need it.
Re: Lobster meat?
Yeah, so
what about the butter sauce?
Re: Lobster meat?
Yep...
John in NM
Years ago when I had my wisdom teeth pulled they gave me a prescription for codine and suggested I try 3 advil first (with the warning to only do that when absolutely necessary). I think motrin was only the high dose prescription then, before they came out with an advil competitor.
Re: Lobster meat?
William Duffield
If it were rough lumber, there could be good reasons to choose a single four-board-foot board over four one-board-foot boards, but as long as I can read the label, count to four, and swallow four pills at once, I'll choose the generic ibuprofen at a significantly lower price. :D
