Clean up and hang air filtration unit
Henry (Raleigh NC)
I continued to do a major shop clean, which starts down the path of considering entire reorganization:
- Maybe I should get rid of that table so I have more room at the lathe,
- maybe I should relocate my dust collector,
- How should I store sheet good (pieces)?
- is that scrap bucket worth keeping,
- and on and on ....
So far I have resisted the re-org temptation, although I better get going on the next project before I give in to the temptation.
I did manage to accomplish organization (not re-org!). A few years back I purchased a used hanging air filtration unit. Never having actually hung it, I just used it on my bench top where it was definitely in the way. I finally screwed several 2x4 pieces into my ceiling and hung this on eye-bolts and S-hooks.
Purchased used, did not have the eye-bolts with it. No problem, I will get some at my neighborhood hardware store - an excellent, well stocked, well run store with great customer service. The threaded inserts in the sheet metal were M6 - sized similar to 1/4-20, but metric. My hardware store did not carry metric eye-bolts, and could not in short order locate a source among their vendors.
Plan B: I had to drill out and cut off the existing threaded inserts and just install regular threaded eye-bolts with nuts and fender washers. That was easy for the front two holes nearest the intake filter, but much more of a stretch for the back two holes. Once all the prep work was done, it was simply a matter of hoisting it to the ceiling. And yes that was quite simple.
I have seen videos of a few methods to hang such air filtration units by yourself, including the four chain and incremental lifting method. I do not have the necessary chain and was loathe to make another hardware store trip and buy some for one time single use like this (although they have plenty of chain). I spotted two long hold down straps - remember I had just cleaned up in the shop and so I knew where at least some stuff was. Having just two straps I wondered if I should use one strap through two eye bolts on each end, or just do two diagonal corners. I opted for two corners. Once I re-ran the straps so that I could pull-down rather the lift-up to shorten the straps, raising the unit into place was a simple matter of alternately pulling these straps to shorten the loop. Note that with this system the 'pulley effect' was in place: pulling 1 foot of strap out of the loop raised the box six inches. It was quite easy to lift and virtually anyone of normal physical ability could have done this.
Once the straps were at the minimum length and with the box within 1 " of desired height, I merely tilted and lifted the box to install the S hooks on the two unstrapped and opposite corners, then released the straps and installed the final 2 S hooks. All of this was easier to do than trying to describe it in words.
All I need now is an extension cord to an outlet; the former homeowner who had this built as a WW shop had lots of wall outlets installed, but for some reason did not think to put any in the ceiling!
I can now see all three primary horizontal surfaces: the TS top, the bench top, and much of the floor. Progress indeed. On to an actual project!
Henry
