Need to cut a piece of 1/4" thick Lexan or if I can find what I know I have stashed somewhere, Plexiglas. Shop told me to score the Lexan but cut the Plexi. Final dimension 30" x 9" x 1/4 off of a 36"x 36" x 1/4" partial sheet.
I'm working with a 10" WoodWorker II carbide 40 tooth blade on a table saw.
What is the proper and safe way to cut this stuff with out shattering the edge?
Doesn't work for me. Too many times I tried with a special scoring tool, and even with that I often didn't get a clean edge. Way too many times I had runnout and bad breaks. Talking to the guys at the local supplier I was told that it takes time to develop the knack of scoring deep enough on a single pass. Multiple passes are difficult to make on exactly the same line.
I've gone to cutting in a single pass with either a 120 (or more) tooth plywood blade set 1/16th to 1/8th inch above the plexi/acrylic. Or I use a high tpi high quality blade made for plastics in my Bosch jig saw and a guide. Depending on the size of the piece I will also use a high tpi bandsaw blade.
Lexan is polycarbonate right? I didn't know you can score and snap it. It's so soft, you can pull a curl with a hand plane, and cold bend it 90 degrees in a sheet metal brake. Acrylic is so brittle, it's more like glass. I wouldn't suggest using a really good saw blade either. It's going to get a build up on it that is not easy to clean. Heat is the killer on cutting with a table saw. Multiple cuts might work if you use a pretty aggressive feed rate. You get the cleanest and best cuts with a C flute router bit.
Lexan or generic polycarbonates are unlikely to crack. If you have the much less costly completive product Plexiglas or generic acrylic sheeting, getting a clean will be a challenge.
Cutting Tips
1 Use only the cleanest and sharpest blades. Dirty and dull blades will get hot and melt the plastic.
2 Raise the blade above the table as far as your saw will allow. In this way each tooth is cutting for the shortest amount of time and will run cooler, also when cutting acrylic any crack will show as a chip along the cut edge. With a lower angle the cracks tend to run from the cut to an edge and destroy the work. Please be very careful with that much blade exposed.
3 If this will be a rip cut take the time to get the fence 100% parallel to the blade.
There are blades made for plastic 10” 72 teeth and a different hook angle.
I can't help with the Lexan, but I've been successful cutting 1/4" Lucite (plexiglas) with a Festool track saw, using a metal cutting blade, and the speed set very low.
I needed to cut a 12" X 12" piece for a project and took some scrap plywood, made a sandwich with the plastic squeezed tightly between, raised the blade all the way, and made the cut a bit on the fast side. Pretty good edge. No chip out. Worth a try.
I have used a lot of Lexan (Polycarbonate) and Plexiglass for machine shields when I was working as an Manufacturing Engineer. I have never seen Lexan crack or chip on the edge. We used a Metal shear when cutting sheets down, Band saw for other cutting, and I have cut it in my shop on my table saw. The only issue I have seen is that it will melt if you have a dull blade or don't use a fast feed rate. When it melts the edge is pulled over and it takes a lot of work with a knife or file/rasp to clean the edge. It is soft enough that it will form 90 degree using a metal brake at room temperature. By the way Lexan is very susceptible to cracking or crazing if exposed to any chlorinated hydrocarbon cleaners or lubricants. We tried it for shields and found the material would actually crack and fall apart where the stress points were (screws holding the shield or attaching accessories) when a chlorinated lubricant was used 20 ~ 30 foot away!
Plexiglass is quite a different animal. It does tend to chip fairly easily. Many of the shields we made were cut with a saber saw as low speed, some cutting on a band saw, I can't recall anyone using a table saw, doubt you could do it without occasionally cracking or chipping regardless of the blade used. Others may have done it with success, and may comment.
I've shortened lexan (polycarbonate) windshields on boats and motorcycles with a fine tooth blade on a sabersaw. These were primarily curved cuts but I would think you could do the same with straight cuts using some sort of guide. Following the cut, I sanded the edges with progressively finer sandpaper until it looked like a factory edge. Just put some wide tape on the lexan so the base of the saw doesn't scratch it as it moves. Worked great for me.
I've also cut plexiglas (acrylic) using a negative hook blade on my RAS. Also sand the edges and then a quick pass on the edge with a propane torch to finish it.
the feed rate needs to be fast enough to take an actual chip for it to take the heat away. Slow feed = melting which self welds onto the side of the tooth, which creates more drag / melting.
ALWAYS use a zero clearance plate under where the blade exits the cut. THis eliminates the resonance which can be induced by the teeth, and will yield a cleaner cut.
NEVER try to back up if you've cut too slowly and started to get melting. The likelihood of a kickback is extremely high if you try. Better to hit the off switch if you can manage that without getting whooped by turning loose.
As for using a jigsaw, I'd rather use a coarse blade, with slow speed, and plenty of pressure for federate, to take a big chip.
Cut plenty outside of the needed final dimension, the dress down with a router, jointer, or even block plane.
If you have a TS sled large enough, you can use it, but once again, put a fresh piece of 1/4" mdf on to make a zero clearance backup support.
I've cut it on the tablesaw, also with a WWII blade. No problem. Feedrate is important, but I haven't cut he stuff enough to give good advice; if it starts to melt go faster.
But the chips go everywhere even with a dust collector - and they have static cling.
Wear at least safety glass and a dust mask. It also stinks when cutting. Can't be good for you.
Faceshield is a good idea in case something catastrophic happens.
Do up the top button of your shirt. If you tuck your shirt into your pants, you'll have plastic chips in your underwear after the first cut.
