"Wax resistant" finish?
What would you consider to be a reasonable finish that you could easily get wax off of?
Our priest, Liz, wants to use wax candles during Advent as opposed to oil filled candles.
The big problem is that even with bobeches (wax catchers) - some wax gets on the stand that holds the candles. So - what would be a reasonable finish to put on the "ring" that holds the Advent wreath and the Advent candles? I would also be putting the same finish on the stand.
Re: "Wax resistant" finish?
John in NM
Poly would be my choice (oil type, not water soluble). Wax would stick but you could easily remove it with some solvent without damaging the finish. Paint thinner or turpentine to remove the wax.
Glass
Dick Coers
If on the altar, you can put down a full sheet of glass on top, or just a piece under the candles.
Robin Corell in Atascadero
Apply any finish you like and then spray it with silicone spray. The wax will come right off.
Can't say I've ever seen a silicone recommendation
Dick Coers
Silicone sprayed on a piece of furniture will render it nearly impossible to refinish. A tiny bit of silicone will cause any new finish to fish eye. Purposely coating it with silicone spray.......... well I just can't imagine it!
Re: Can't say I've ever seen a silicone recommenda
Robin Corell in Atascader,ca
Silicone is commonly used as a mold release when pouring wax in rubber molds. I probably wouldn't spray it on a table which is l likely to need to be refinished at some point, but I see nothing wrong with applying it to a candle holder in an effort to keep from damaging the finish when scraping off melted wax.
Lotta good suggestions here
I'm going to try the silicone trick, on poly. I'd recommend making a wooden scraper, too, with a sharp edge to pop the wax off. Make it fancy so it complements the furnishings.
Re: Lotta good suggestions here
Works for me.
I was planning on urethane. I will top coat w/ silicone or Teflon spray.
