Does this actually exist?
Howard in Toronto
Is there anything such as 1/8" diameter router bits? If possible, I'd prefer a 1/2" shaft.
Or does anyone know about end mills or...
Thank you.
Howard
Re: Does this actually exist?
jessecloud
Try Lee Valley part number 15J06.00
Never seen one on a 1/2 shaft, though.
Buy more than one. Router bits that size are fragile. Take light cuts.
David Yoho
If you mean straight bits, then yes they are widely available with a 1/4" shank. I've not seen one with a 1/2" shank anywhere.
Not only does 1/8" exist, but I have a 1/16" as well. However they come with 1/4" shafts. This can be used with an adapter sleeve for use in a 1/2" collet. I have done so very successfully.
Don't know if you can find them in 1/2" shaft sizes, but Dremel 1/8" bits with 1/4" shafts are widely available. I have a router base for my Dremel and it is handy for small work. If you plan to use the bit in a standard router, you may want to buy several as they are fragile!
Several bit sets are on Amazon site > https://www.amazon.com/s/?ie=UTF8&keywords=dremel+router+bits&tag=googhydr-20&index=aps&hvadid=153728571997&hvpos=1t2&hvnetw=g&hvrand=16518723616796596952&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9016053&hvtargid=kwd-11192812&ref=pd_sl_6d3jtfpymf_b
I have also seen some at my local ACE Hardware.
I did a search a while back but don't have all that info now. I found them in some metal working catalogs as end mills. I believe it was MSCdirect.com. Stewart McDonald has very small ones with 1/4" shanks. I believe MicroMark also has them in small sizes. You can of course get 1/2" to 1/4" adaptors. I made a 3/8" to 1/2" adaptor to take some end mills that only come in 3/8".
3/8" PC collet are around as well
Henry (Raleigh NC)
At some point Porter Cable also made a 3/8" router collet. I have one, although I have never used it. Don't know if they are still available.
Henry
I'd suggest solid carbide router bits
Dick Coers
With small bits like that, getting the chips out of the groove is an issue. If you want to consider an end mill, look for high twist that are used for aluminum. It will take some time to learn proper feed rates and light depth cuts are necessary. You can get up cut and down cut bits that are used with the bushing inlay kits. Most kits come with down cut, I prefer up cut. You will get a little fuzz on the top surface, but the chips clear out so much better and you hardly ever burn the cut. Basically no real chip out with that tiny of bit.
Almost
John in NM
You can get router bits down to 1/16" for straight plunge. Only in 1/4" shank though. Tools Today sells the bit and the 1/4" to 1/2" bushing (those are handy to have - I'd rather have 1/4" bits in general and use bushings, then when you get another router that only takes 1/4" you can still use them).
How about 1/32?
Line and berry inlay is 1/32. Bits for the straight runs are available even at Lee Valley. Every place that sells to machine shops will have bits down to at least 1/32. I use the solid carbide but they are fragile.
