painting oak
painting oak
painting oak
Eric Kuehne
I want to paint my oak kitchen cabinets (I know) and am looking for a relatively easy way to fill the pores. The goal is that there will be no trace of them in the finished product. I've done some research, talked to paint companies, trolled the www but no real luck yet. I was hoping a high solids primer might work but haven't had any luck there. Some people talk about filler but I have a big kitchen and would really like to avoid that much work.
If any of you have any experience or advice I'd love to hear it.
Thanks,
Eric in Los Gatos
Re: painting oak
Re: painting oak
tom
Here is a trick I learned when wanting to fill the grain on luan doors. I skim coated with drywall compound, sand, prime, then finish coat. I also did it on a stair case where the spindles where stained oak and the new finish was white. Worked great !
Re: painting oak
Are you talking about red oak?
Re: painting oak
Re: painting oak
Don Stephan
Joint compound might be the best approach if it will adhere to the existing surface. More difficult to use, but I was always told setting type joint compound adhered better than premix.
Re: painting oak
Re: Are you talking about red oak?
Eric Kuehne
Yes. Red oak. Should have been specific.
Eric
Re: painting oak
Re: painting oak
John in NM
I doubt there is an easy way to avoid traditional filling. If you want the grain completely invisible, you're pretty much going to have to fill and sand it down, then primer, inspect, and perhaps sand some more.
You could try something like Durhams water putty for the filler, as you can thin it easily. Not sure how much it shrinks with added water though. I think its water soluble still after it dries, so you might be able to apply it and sponge it smooth, then re-apply and sand - sponging will give you dimples where the grain pores are. Sanding will too, but to a much less noticeable extent.
Re: painting oak
Re: painting oak
I have used sheet rock compound on pine shelving boards before painting them. It worked very well and held up for years. OTOH the wear on closet shelves would be very different from cabinets.
I would also try Zinsser 123 Primer or Kilz. I like the Kilz Original. As a friend said, "If it don't stink, It don't work". If you are worried about the odor and the VOC's you might try Kilz ll. These are heavy bodied primers and may fill the pores well and require little sanding.
Being kitchen cabinets, clean well before priming.
Re: painting oak
Re: painting oak
If avoiding "that much work" as would be involved in filling is essential then look into refaceing them with birch or maple. Getting filler to stick on a finished surface might be difficult.
I doubt any treatment is going to work to yield a grain-free surface so experiment on some test pieces before committing to the entire project.
Re: painting oak
Re: painting oak
Joseph Mulherin
Eric, I agree with Bill Tindall about refacing the doors with birch or maple facings. OR, go to Home Depot or Lowes and buy new doors. Trying to fill in the pores with compound is going to be too much work you do not want or need. See what the wife wants.....SWMBO!!
Re: painting oak
Re: painting oak
Paul Leuba
I've had good luck with Kilz oil based primer on red oak spindles on Windsor chairs. It has a high viscosity and it dries with a smooth surface. I suggest you try some on a sample patch inside a cabinet before committing it to the entire job.
Paul in Hunt Valley MD
Re: painting oak
Re: painting oak
Sponge sanding drywall joint compound works, too.
I don't think there's any way to avoid work on this project. Filling pores on wood as porous as oak takes work.
Re: painting oak
Re: painting oak
Eric Kuehne
Thanks all for the advice. I think that, based on the amount of work involved, I'm going to get a reprieve from SWMBO. Still good advice and I may have to experiment a bit just to see.
Eric in Los Gatos
