OT- Tablet question
Thomas E Norton
I am looking to replace my Nexus7 tablet. It has a 32gb memory. I heard an idea about getting a 8gb one and using a micro card. Is there a disadvantage to going this route?
Thanks!
OT- Tablet question
Thomas E Norton
Thanks!
Re: OT- Tablet question
Stuart Johnson
I think it depends on the amount of data you are currently using, the hassle of changing cards if one won't be enough and the cost difference.
Bill Howatt
My guess is that the card has slower memory access than memory native to the tablet motherboard but I'm not certain.
I have a HP Stream 8 tablet running Windows 10 that was bought strictly for fooling around and playing MP3s. I think it is 8GB and I have a 32GB SD card in it which the MP3s are stored on and it works fine. Using SD cards for changeable storage would not be convenient with this device since you have to take it apart to put the SD card in since it doesn't have an exterior slot. But that is a non-issue since the 32GB card is more than I need.
With 8GB (less the OS and apps requirement) as your main storage it shouldn't be too hard to put files you consider needing quicker access into that area (if it is an issue and I have my doubts it would be).
For my limited use the SD card method is just fine but you need to factor in the cost of the card to see if you are saving any money if that is the idea.
Bill
Walt
I'm not experienced with tablets or Android so take this for what it costs you ;-). Check if apps can be stored on and run from an MicroSD card. I think the newer versions of Android can do that but it may depend on the app's writer and/or device hardware. My Android phone uses about 6 GB for system and AT&T bloatware.
