To make or mend?
CJ in MPLS
Coming home from work last night I stepped past a shop cabinet I'm building to help clear up the mess in the garage and noticed that two of the drawer boxes I've made are a bit large. These are large 21" deep x 30" wide drawers and are made with 1/2" plywood (the Ecuadorian stuff) from the Home Depot. What I did is to make the boxes 1/2" narrower than the opening into which they will fit. As 1/2" inch is needed at both sides of the drawer box, I cannot use the slides I had planned to use.
I don't think that I can cut an end off of the box and reattach it. I could route a 1/4" dado in the cabinet sides on each side to gain my 1/2" clearance. Alternatively, I could simply remake the two drawer boxes. The latter two options are easy enough to do.
So, what say you? New boxes (out some time and $) or the quick fix that I'll be looking at for some decades to come?
CJ
Then shim out the two smaller drawers to fit the cabinet.
