Windsor suggestions please
Gary Smyth
Street find of this decently made Windsor last Spring. Broken back. Old but not valuable as an example. Started in the summer and roughed out tapered ends on a new back and steamed it into shape. All left to do was fair the curve, smooth, insert the spindles and center the back piece, wedge the back into the chair arms, then paint. Did measuring and spacing but hit a snag.
The spindles do not go through the bent wood back. The bentwood back of the original has spindle holes that are blind. I could not figure how to accurately drill into the rounded underside about 5/16 to ½ inch at the proper angle. I set the chair aside.
Time to complete this project.
I’ve watched many videos and have little to know. The back is awkward to handle and clamp if off the chair. If on the chair I figure a brad point bit in progressive diameters will work if I work from the underside and keep the hole and mortise blind. Much easier would be to work from the top, with the back in the chair sighting down from the top, making a through hole and then plugging the top hole after the spindle is seated and glued. None of the spindle tops were wedged, only glued.
Who knows the indignities this chair has suffered, but I like the paint wear, scratches, flakes and deterioration so only the back will be painted. This is to be a porch chair, undercover, but outdoors most of the time. So chair makers, restorers, anyone out there care to suggest a method to seat the spindles on a chair such as this?
Re: Windsor suggestions please
I usually drill from the top - but I usually don't have the spindles in the holes when I drill.
The brad point bit will work - as will any bit that has "spurs". I usually use a brad point bit. My holes are usually at the correct size and I split my spindles and use wedges.
What I have done in a similar situation.
Clamp all the spindles to the hoop - making sure that the spacing is correct and also clamp the center splat.
Drill the holes for the middle spindles (between the splat and the ends of the hoop).
Set the middle spindles in the drilled holes.
How to drill the hole (somewhat accurately) - make a block (hardwood or metal) with a V that has a drilled hole coming out of the bottom of the V. Use it to guide the drill bit to the center of the hoop as you drill.
If you can offset your hole so that is just off center so that the hole will be "just" in back of the center line, that would be great - otherwise centered is fine.
If you think you can do it w/o a block, that's good also.
I have some 3/8" and 1/2" rat tail files that are fairly fine and have a bit of taper on the ends. I use those to smooth out the holes.
Mortising out the splat hole will be interesting.
Bruce, a MN Galoot
I recommend that you post this question on the WC Handtools forum. There are a couple guys who hang out only there who are real whizzes at Windsors, in particular Jack Guzman.
Jack Guzman from Maine
Gary,I think I would sight and drill from the top using a small bit,then take the bow out of the chair and finish drilling from the bottom with the right size bit. Alot easier to disguise smaller holes. Use a 1/16" bit for the pilot hole and use this hole to center a brad point bit of the right size from the bottom. With the bow upside down in a vise use a 1/16" bit in the hole to get the angle. Clamp a small straight edge of some sort as a guide on the side of the bow in the correct angle,then drill your hole.Good luck. Post the results.---Jack
Keith Newton
Gary, do you have any aircraft drills? If not, you can buy individual bits from Ace, or big box stores.
If you spring clamp the spindles to the back of your new part, you could make a little saddle spacer to hold you up to center, then line up with the spindle. A small 1/8" bit which is 12" long is so flexible and smooth that you can bend it out to get your drill motor away while guiding the bit from the middle with your other hand.
This outside ones which are at such a low angle are the trickiest. Bring your bit around to about square for the first 1/16, then swing on around as you deepen the next 1/8". Practice on a scrap, maybe your old part that your replacing. You'll probably need to aim high by 3/16" expecting a little drift, not only from your pilot drill, but your larger bit.
If you have a set of countersink bits, you might take the collar off a 1/8", and put it on the bit backwards or a nail that size to slip well down into your pilot hole, to keep your larger hole from drifting down the grain slope.
Or if you have some small carving gouges, you could carve that upper half of a hole, so your spur can be well into your pilot before it starts cutting.
