hollow core door glue up
I had to cut down an oversize hollow core door and fill in the gaps left. I used all of my 12" and under clamps. I still had to route out the center pressed wood and put in a spacer but decided to do that after the initial glue up. Just for interest sake I counted my clamps. I have 143 and still could use some more.
Re: hollow core door glue up
Dick Coers
I you had used some straight cauls you could have used less than half those clamps.
TomD
Brings back memories. I had to do 5 of those in order to make use of some "bargain" doors I bought. Some of them were trimmed from all 4 sides.
You are correct Dick but I didn't have any boards that long. I keep a set of cauls that are 4 feet for gluing up panels. I had these clamps 5 feet away so it was just easier to just grab them.
Don Orr
Looks like fun ;) :b
I did something similar when I replaced all bypass closet doors in our house a few years ago. I mostly just had to cut them to length and glue in a solid piece.
Keep up the great work!
You Mean
you didn't "put in a couple of bards to hold 'till the glue dries"?
hmmmmmm
:D
There's only one Bard, but
Chuck Nickerson
perhaps he had many illegitimate sons named Brad who could do the job?
Just feeling silly...
The Truely illigitamate ones I don't know about
William Duffield
I have plenty of very cheap spring clamps I made from 4" Sch. 40 PVC pipe. I cut it in rings 1" wide on the bandsaw and cut one kerf across for the jaws. You could make them from 5" or 6" for a bigger grip, or from DWV for less spring pressure, or cut them narrower for less spring pressure or wider for more.
To Hold
or not to hold. T'was the question, eh?
John C Lucas
I forgot to count all the spring clamps. I probably have 30 or more of those. For certain glue ups you just can't beat them
