REAL MILK PAINT
Need joinery suggestion
Royce Meritt
I am building a fishing rod case for a friend. Think a rectangular "box" about 6" High X 8" Deep X 80" Long. Glued up into the box shape, then cut apart to make the top and bottom. I need suggestions for the best joint to use on the corners. I would love to use box joints but because the sides of the case are 80" long, I really can't cut the fingers.
Any thoughts? Lock Miter? Locking dado? Regular dado joint with triangular glue blocks inside? Thanks.
Royce
Re: Need joinery suggestion
Gary Smyth
I wonder about the dimensions. A bit more please about the rod. Doesn't it break down into sections? Most rods do from the lightest fly rod to the mamu deep sea rigs.
As to the joinery, a dado bottom to sides and a hinged top(maybe a piano hinge) will work as it is built to protect the contents, not the box, and at the projected 80" length will get in the way of a lot of stuff.
I sure would like to see the rod and the reel if that is part of what is included.
Royce Meritt
Nope, the case will hold two 1-piece rods. Thanks for the thoughts.
John McGaw
I'd have to question "I really can't cut the fingers". I don't know of any reason why it couldn't be done as long as you are willing to adapt and use some 'field expediency' as we used to call it in the AF. I'd agree that using a tablesaw and dado blade or router table and straight bit, the most common methods, would be insanely difficult but how about a handheld router and jig? The latter is the best way I've found for the job using my Leigh jig but there would be no need to go to that extreme as you could manufacture a satisfactory one-time jig using nothing more than MDF. That and a pattern bit should get the job done pretty quickly.
I agree with dovetails. But, If you don't want to do that, how about "keys", triangles inserted in the corners? Pretty easy to do and reasonably strong. You can also do dovetail keys.
Keyed miter joint
paul in AZ
A keyed miter joint would be dead simple if you have access to a bandsaw or just cut them by hand.
I use these regularly and the bandsaw is quickest for me.
Two bandsaw blade kerf widths [+ or -] is wide enough for an attractive and functional joint. Cut before assembly, glue and tape the miters and then insert the keys.
Bruce, a MN Galoot
If not dovetails, try splined miters
TomD
Visible splined miters, not the invisible kind. Dead easy, and lots of design options.
Re: Thinking Outside the Box
William Duffield
Is this case for display or for transport? If for transport, use Sch. 40 PVC with an end cap one one end and an access port on the other.
The problem with most of the jigged power tool solutions offered here is the length of the side boards, almost 7', vs. the height of the shop ceilings. Hand cut dovetails don't have that issue. Further, they can be laid out so that the the joinery and the kerf that separates the lid from the box avoids the joinery.
Splined miters are relatively easy to cut with shorter boards and a jig for the table saw or router table, but supporting the 80" sides at 45° is a real challenge.
Any power tool solution needs to bring the cutter to the long boards. The quickest, easiest way to do this is a miter with loose tenons cut with a Domino. Unlike a router-cut splined solution, you don't need a jig with a bunch of angles and joinery as complicated as the box itself to support and guide the router.
