How much glue for vacuum veneering
There was a recent discussion on gluing the veneer and it seemed to me some were using way too much glue. On the one hand I haven't done a lot of vacuum veneering so I shouldn't be lecturing on how much glue to use. But on the other hand I test adhesion on the edge trimmings and my veneer is well stuck.
I coat both veneer and substrate with a thin layer of glue, like I was painting with the paint roller. As you can see, some black marks on the veneer can be easily seen through the wet glue. I have found this amount is enough. More is apt to leave puddles which lead to bumps.
Re: How much glue for vacuum veneering
pecker
I have done a lot of vacuum veneering, though I only roll the glue onto the substrate. Many veneers will just curl up if you moisten one side with glue, making them difficult to lay onto the surface and get into the vacuum bag.
I roll on like painting a wall with a fairly heavy coat. The instructions for Titebond cold press veneer glue says to apply 6 mils thick.
jcousins
i apply glue only to the substrate using a 1/8 notched trowel. most of my experience is with unibond - using 5/64th home cut veneers. i have always shied away from using a roller just cause so much glue is absorbed and then washed or thrown out.
jerry
Dick Coers
I use a rubber brayer to spread the glue. Darryl Klein recommends a coat of adhesive that will form a small bead when you drag your finger across the surface. I also only spread on the substrate, especially when veneering both sides at the same time. I feel the first veneer would soak up too much water if coating 4 surfaces before laminating.
Sgian Dubh
Bill, as with the comments of others I don't apply glue to the veneer, and for similar reasons they've given - it causes the veneer to curl which can make it difficult to lay it down flat, and increases the risk of wrinkling under the applied pressure.
For vacuum veneering, whether in a bag or press, I put down a flat sheet of manmade board inside the bag or press, then a layer of plastic, then the veneer face side down. Apply a coat of adhesive with a painter's short nap fibre (wool) roller to the ground: I aim for about 1 - 1.5 mm thick of adhesives such as PVA or urea formaldehyde type, then flop the glued groundwork onto the veneer, line it up and apply pressure. If the panel is large it's advantageous to put a stack of diminishing boards (to form an approximate stepped pyramid shape) on top of the groundwork inside the bag or press. The next stage is to remove the veneered panel from the bag or press, trim the overhanging veneer straight away, then veneer the panel's reverse side using the method just described.
I can't recall ever having a failure using this methodology (although it is possible my memory has failed me), and I've used a wide range of vacuum bags and presses for this task probably many scores of times over the last thirty or more years. I would never use your method of applying glue to the both the veneer and the ground - it causes far too many problems with the veneer because it curls and wrinkles in response to the water in the glue. My best advice for consistently good results is keep the veneer glue free until you drop the freshly glued panel onto it, and apply the pressure as swiftly as possible. Slainte.
EdSnow
I will relay what some of the glue manufactures say about pva and rollers for veneer. Works but . . . you still end up with many times more glue than you need. Fine by them as you are paying for the glue. Their preferred roller method is a very thin nap roller or a brayer and then a screed with the correct height and width to pull off excess glue. The other manual method they suggest is measuring out glue into a cup for a given surface area and then applying that and no more. This is a much better method according to them. Both scenarios require one to work fast as both the core and the veneer will take the moisture out of the glue, so it is best for large faces to tag team.
The roller method has some unintended consequences in some veneers as that much moisture is a recipe for an occasional split face. Two separate split types occur, seam splits if your face is solely edge glued, not stitched/taped and glued, which is common in commercial veneer and thick veneers. The other being splits within the plate, more common on flat sawn veneers. I have had both happen using the roller method at work but yet to have it happen to me other places. Anecdotally, very dry thin veneer being the main culprit or core that is burnished.
Most also will only recommend you only apply glue to the core and just mist the veneer face with water to balance it out. This also makes sure that the core which can cope with the excess moisture does and you don't unintentionally increase your odds of the split face.
I have often thought it would be great if someone would make a silicone roller with grooves in it that would hold a little more glue than just a brayer but also only apply a little. The only solution out there like this is a silicone roller with a feeder tank which is a real p.i.t.a.
Good points from all and some comments
I am late to the veneer party. I have brought my edge gluing habits with me, namely, use as little glue as will do the job and coat both surfaces, which enables using little glue.
I use a foam paint roller, a tip I got from someone that routinely veeners boxes for sale. It does not waste significant glue, it is easy to clean and reuse and it can be bagged for several days if one is veneering over several days.
I have tried brush and vee grooved card as I learned in the Headley shop. The roller is times faster, lays down an absolutely uniform film of glue and the thickness can be controlled. The panels I just finished were glued in a fraction of a minute.
To bond, both faces must be wet by the glue. If only the substrate is coated a thicker coating of glue is needed to ensure wetting of the veneer face. Because I am laying down a thin layer of glue I don't get the excessive curling I used to before the roller. Once I put substrate on veneer the thin glue layer tacks almost instantly. I don't have to worry about it skidding around before the air is pumped out. I have so little glue involved I don't expect to ever see any issue from moisture, or at least I haven't.
I am using ordinary white or yellow glue, as I learned in the Headley shop, and this glue may behave significantly different from "veneer glue". What I do may be inappropriate for thickened veneer glue. Some, maybe all, the veneer glues contain filler to increase the viscosity. I have so little glue involved that glue running here and there under vacuum is not observed.
Possibly because less glue (and water) is used the box person routinely veneers one side of 1/2" plywood with out any warping observed.
PS wet veneer stays flat
What is shown in the picture is the veneer, with glue, sitting there while I fetched the camera I forgot to get ready. Note, it is flat.
That seems like a lot of glue
Henry Higginbotham
Even at the low value of 1.0 mm thickness, I calculate that a gallon of glue would cover just 40.7 square feet. I suppose my ciphering could be defective -- did anyone else work that out?
Agree
that seems to be a vast excess. All that water then needs to go away. At 40% solids that leaves a glue layer 0.4 mm thick, too thick by an order of magnitude in my opinion. There is nothing special about gluing veneer that it requires a bond any different than an edge joint. Nobody should be laying down a 1 mm deep glue depth on an edge joint either. But at least here the excess will squeeze out to become a mess to clean up later.
Again in my opinion, one should learn to apply a small excess of glue( for insurance) beyond the minimum needed.
Re: Agree
Sgian Dubh
Bill, both yourself and Henry have noted a problem in my assessment of the glue film thickness I typically apply to the groundwork when I'm veneering. My thickness assessment was based entirely upon memory of the visual appearance of the glue after it's applied, therefore both subjective and fallible. I also forgot to mention in my earlier post that if I'm using PVA or aliphatic type adhesives I usually thin them a bit, 'guestimating' an additional 5% or 10% of water just to make the rolling out, or brushing out which I occasionally do, a little easier.
So I cast my mind back to some of the veneering jobs I've done in the past to try and recall how many litres of glue (plus added water) I used to veneer panels of dimensions I can also recall. Bringing one panel to mind of approximately 1800-1900 mm X 1220 mm (~72" X 48") I'm fairly certain I used about 0.5 litres of slightly diluted adhesive per veneered side. I crunched some numbers based on this, I grant, less than firm recollection, and discovered this results in an average glue film thickness of ~0.225 mm or a bit under 9 mil.
Of course, this result goes to show how inaccurate my visual estimate of film thickness almost certainly was. Extrapolating numbers from the above more recent calculations indicates I might typically use about 1 litre of slightly thinned adhesive per 2.24 m² (or ~48 ft²). Further extrapolation suggests a US gallon (3.79 litres including about 5-10% of extra diluting water) applied as I've just described should cover approximately 182 ft².
Naturally, I could be wrong again because as before, I'm still relying on memory, but I suspect this is significantly more accurate than my earlier effort. So please accept my apology for posting some erroneous and unhelpful 'information'. However, the rest of the methodology I described for veneering jobs in both hot and cold vac presses and bags, as well as screw activated cold presses and heated hydraulic presses, is pretty much the routine I've used for more decades than I nowadays really care to remember, ha, ha. Slainte.
Re: Agree
TomD
You are right there is no difference in how the wood would respond as far as it's needs for a bond.
There can be a huge difference in the amount pressure from bagging, which is normally very low number like 2-14 psi. Low pressure means low displacement of glue. There is some kind of hydraulic rule of viscosity x pressure = some minimal film thickness. All the excess glue is simply not going to move out. But it can leak out badly through flaws, which are very common in materials like burl.
Vac bagging is often undertaken to dry out composites, so the wet should not have much difficulty escaping.
We all want the right amount of glue, and it really doesn't seem to be all that difficult to arrive at. I have done a lot of vac bagging, in sizes up to 100s of square feet. Can't remember any failures due to too much glue. Though I am certainly not trying to use too much glue.
