There's an article right there...
Grant Smith
Thanks, Bill.
My Delta DC-380 planer was rescued from a failed small sawmill that thought they'd plane the lumber right as it came off of the mill. As you well know, there are so many things wrong about that approach that one's mind is boggled. I recall asking the seller if he meant to say "when the lumber comes out of the kiln", he said.. "Nope, we save steps by planing before it goes in the stack for air drying". Sheesh. I let it go at that, but I did use the condition of the planer to get a great price, $300. He had a WoodMizer that was also for sale. Both machines had been kept inside, looked nearly new, except for the rusted table on the planer. They had only milled around 6,000 BFt, according to him. The market dropped to where it wasn't profitable was his reason for quitting.
Anyway, my planer was had for a song, but it needed lots of rust removal from the green lumber. To be honest, once i got it cleaned and the rusty beds polished, I started using it without a thought of the infeed/ outfeed settings. Now I wonder if they had cranked the infeed roller down to get it to feed through the rust and (probably) uneven green boards.
By the way, I don't really recall exactly at what thickness my planer will show infeed roller marks, just going from memory. My process now uses the Wixey gauge, first finding the depth before sliding in the stock, then raising the cutter head in increments of 1/2 turn of the height adjustment until the board is admitted. So I have developed a workaround that has been fine for my needs. That said, now that I know more, I will dig in and see if the machine can be adjusted for the better.
Thanks again,
Grant in Iowa
