Advice needed on floating shelf system
AZ in Colorado Springs
Some friends want to put a floating shelf in their bathroom, with no visible hangers or mounting system. They have a piece of 8/4 pine with a natural edge, about 36" long and 9" wide, for the shelf. It's solid (of course), and likely pretty heavy for use as a floating shelf.
How can this be mounted? (I don't think it'll butt into the adjacent walls.)
Thanks Andy
Re: Advice needed on floating shelf system
George Koch
I would use 1/2" steel rods drilled into the wall studs and the rear of the shelf. George
I have done a few of these. I either bought or made a metal plate with a keyhole slot in it and mortised it into the back edge of the shelf. I positioned them to line up with the studs. Drove a big heavy round head screw into the studs and left it standing off the thickness of the plate. They worked well. A little tricky to get the standoff distance just right. You want the plates nearer the top edge of the shelf. Plate needs to be very stiff and the screws need to get a really good grip both ways.
Not sure I ever did one out of solid pine 9" wide. Most of mine were about 2" thick and hollow. Some of them had legs back to the wall.
John McGaw
I helped a friend in Alaska do this job in this way many years ago, before I took up woodworking. The hardest part was ensuring that the holes in the wall/studs and the shelf lined up perfectly. Looking back at it I seems that getting the holes level would be a possible trip point too although we just winged it and it worked. We were using wood that was maybe 6/4. Don't recall what the diameter of the rod was but we were careful to get as deep as possible into the studs without going through the other side.
Bingo!
You need to hit at least two studs, obviously, but it isn't hard to put a good perpendicular hole into a wall stud. I used to do it with a 12" aircraft bit. Make a drilling guide out of four rippings of plywood, mounted at the end to a, say, 6" square base. Place this fixture on the wall and drill through it into the stud behind the drywall or whatever. Plain old cold-rolled steel rod is more than adequate for this.
Re: Bingo!
Don Stephan
Ah, but finding a 12" aircraft bit . . .
A varient
I have used this approach for box shelves/mantles but it could work for solid by hollowing out the back.
Bolt something like a 2 x 2 to the wall. Hollow out the back of the beam to accommodate what is bolted to the wall. For a box beam it is built with the hollow in the back so what is hard with a solid beam is easy with a box beam. Slip beam over 2 x 2 and screw it to the 2 x 2 with trim screws from what ever direction hides them best.
This approach solves the issue of getting projecting rods aligned well enough.
Drill bits
A 12" by 1/2" drill bit is not too hard to find, nor too expensive. You could do it with a shorter bit with a different fixture to align the hole. If you make the fixture from a piece of hardwood 2x material, it will hold a 6" bit straight enough to make this hole for your shelf support. If you want to use a shorter bit than that, consider a 1/2" drill bushing in a piece of plywood.
Good variant
This is how torsion boxes are usually cantilevered from walls. I have done many of them, of various proportions, with good success. I never hollowed out the back of a long grain beam to accept a wall cleat. I suspect it might be more prone to splitting if enough weight were applied to the shelf, but, again who's going to be storing their anvil collection on cantilevered shelves?
One tip I might offer on hanging shelves this way is to cut out a little rectangle of your drywall at each stud location where you plan to bolt the cleat, and replace it with a small piece of wood that will not be subject to compression by the bottom edge of the torsion box or cleat.
Re: Bingo!
Brad Chenoweth
I've done jobs like this with an old Portalign drill guide.. Works well, plus there's the gizmocity factor...
Brad Chenoweth
Thanks to all for the tips. The ideas you mentioned are what came to mind for me.
I've seen the "metal plate" method that Barry mentioned in a (dreaded) Ikea product that I installed for someone, but that was a pretty lightweight shelf.
I also considered suggesting the hollowing of the back and mounting the shelf on a cleat as if it was a torsion box, but an 8/4 board morticed to accommodate a 2x2 would leave about a 1/4" of material above and below ...
Their "other" project is mantle similar in many ways, but I think the board is about 7" thick (28/4?) so I think that morticing will work much better.
Re: how about commercially made problem solver
I'll send 'em the link. Thanks
