A55 Smoothing Plane
A tip for making thin molding
The task is to apply a bull nose molding to this display cabinet top. One possibility is to route the profile on a wider board and rip off the narrow strip to be applied to the top's edge. The problem is that I find it hard to rip a thin piece and get a glue line surface on the molding piece.
Instead, I ripped strips and drum sanded them to the correct thickness. Next I stuck a strip to a backer board with double sided tape to provide support for the thin stock. With the to-be molding strip stuck to a stiff board I ran it past the bull nose cutter. In the "staged" picture I have off set the applied piece so you can see it better.
Re: A tip for making thin molding
Good idea, with quality double stick tape.
In hand work, it's common to plow a groove in a piece of stock to fit the molding, with a stop glued into the groove to retain it as the molding plane works it. For complex profiles, this might not be a bad idea with even power tools.
Show off
CJ in MPLS
This is a pretty thin excuse to show off that plane again.
