Steel legs?
Steel legs?
Steel legs?
jessecloud
Anybody out there use steel for legs in their furniture?
I was impressed by the use of thin steel legs to support a desk posted by Derek Cohen in Bill Tindall's "Desk of the Future" thread.
I'm ignorant in the field of metalwork. Using those legs as an example, what would one need to do to cut the steel and tap it (?) for bolting onto the desk? Would I take plans to a fabricator and if so are we talking about a lot of $$?
Thanks for the help and for keeping me out of trouble here.
Re: Steel legs?
Re: Steel legs?
Dick Coers
At my local steel shop, each cut with a miter cold saw costs $1. Accuracy is a guy with a piece of soapstone and a tape measure. It will take extra work on a stationary disc sander to bring 4 legs together at the same length. Depends on wall thickness of the rectangular tubing if you could get by with tapped holes. 1/16" wall thickness would only give you one full thread on a 3/8-16 bolt. I would want a weld nut, or another way to get more threads. I don't see the advantage of steel with those simple pieces.
Re: Steel legs?
Re: Steel legs?
Brian Holcombe
A fabricator can be quite precise.
My complaint with metal legs on furniture is that most of the designs I've seen do not do well to support the solid wood top. Yes, they keep it 30" from the ground just fine, but most do nothing to help the wood resist cupping or bowing or what have you.
I suspect doing so is avoided because it is not a simple task.
Re: Steel legs?
Re: Steel legs?
TomD
Metal is not all that stiff compared to wood. We had some discussion ongoing on planes, and I forget why, but I measured a wooden jointer vs a metal one for deflection under weight. The results were almost identical. The wooden jointer is about half the weight though more massive as far as being essentially square, but the point remains that if one wants to really support wood, assuming that is generally possible, then one is probably going to be as well off in the design using wood.
I don't know if we are thinking of the same kind of designs Brian, but all those coffee tables and such that have very thin legs often screwed into brackets, those mid century pieces in general, that high design stuff, is as you know mostly plywood.
Re: Steel legs?
Re: Steel legs?
Brian Holcombe
Exactly, and they're supposed to be plywood and the designers that do them right make them from plywood. Finn Juhl, for example, uses a beautifully made steel base under his Nyhavn table, with a plywood top.
It's when that sort of base is attached to a live edge slab that it raises an eyebrow for me. With few exceptions, I don't often see metal bases that do anything any good under a solid wood top.
Re: Steel legs?
Re: Steel legs?
TomD
"Anybody out there use steel for legs in their furniture?"
I never have, though I like the effect created in that piece, it looks like mill run finish on the metal, which certainly reduces the finishing time. That will rust with any pacing breath of moist air, as from a shower or open window on a rainy day, so a clear coat or paint finish might be an idea.
I have made several pieces around the shop, and if I get a minute I may shoot a few photos just for fun.
"I'm ignorant in the field of metalwork. Using those legs as an example, what would one need to do to cut the steel and tap it (?) for bolting onto the desk? Would I take plans to a fabricator and if so are we talking about a lot of $$?"
My experiences with fabricators led me to do all this work myself. First problem for me when I was working was using up scarce vacation days just to get to then, and pick-up. But around here they don't want to talk to you. Now in the neighbouring province of Quebec there is a welding shop in every small town, and all over cities. Welded balconies and fire escapes are all too common on everyday lowrise architecture.
Making this stuff yourself would be pretty easy. This is not the hand tool forum, so if that means you lack patience waiting to see stuff happen, :), you might want some power tools. However, the materials shown can be cut relatively easily with a good hacksaw, and a good blade(S). The alternatives are to buy a bandsaw, either portable of stationary, these are cheap particularly if you have space for them and wouldn't mind acquiring a few old tools. New you can get a portable for 140 at HF and a 4x6 stationary for 250. These things are often available for even less. As with wood get a good bimetal blade.
Another option that requires some skill is to use a cut blade on a 4 inch grinder. This is surprisingly fast and accurate, you want to do this out of doors as you will never get the disc dust out of your shop if it is anything other than shower stall like. You can pick these up for under 15 or 30 at HF, check out the reviews on YT, I think one of these has a good reputation. When I bought the two I have they were in the 150 range a while back.
I like stationary grinders to trim things up, but you can use a 4 inch for that also, different blade.
If I were making this part it would have the legs set A style with a small plate across the top, welded down, and and either a gusset plate and/or some tabs. Tat way it could be secured both to the top and the apron. HF has an excellent stick welder that would do the job very nicely they are under 160. Item #61749. But you could braze it badly with a propane torch, and given this is minimally load bearing you would be fine. The problem with that kind of stuff is you don't build real skills, in a sense.
I can normally find those small drill presses around here for 23 bucks, they make good guts for CNC machines. And and drill metal like it isn't there. So do cordless drills on slow, you can also use them to run a tap. I don't think I would use a tap on this project. A nut could be brazed in place, or just joggled into place if you don't think it will be taken apart much. The tap and die sets are super useful anyway, for failed screen doors, and getting rusted tools working again. All kinds of stuff. I stopped forcing things and just made them right. The chinese sets seem generally fine, however, I do not use the handles, every one I have tried has broken in a way that could cause injury. I replace them with heritage handles or buy new ones from serious, if cheap, places like Victornet.
Re: Steel legs?
Re: Steel legs?
John in NM
Depending on what you had in mind, you could do a great deal of it on your own with an angle grinder, a drill, and a tap.
The local fabricator can be really hit or miss - friend of mine in Tucson used to do the kind of thing you'd come in with, because he was interested by it. But a shop that would make 50 cattle guards for the USFS would overcharge and underdeliver, IMHO.
I'll have to go look at the desk you mention, I got busy and missed most of that thread. I find most steel/wood to be a bit hard to pull off, its really easy to get lazy with the steel.
Re: Steel legs?
Re: Steel legs?
John in NM
Went and looked at the desk. You could cut the legs and the angles on the ends with an angle grinder (leave ~1/8" long) then use a belt sander and angle block to sneak up on the measurement, not too hard. The tricky bit would be that I would want to weld the legs to some 1/4" strap that then gets screwed to the wood top. Anything less would kinda wobble too much. I would probably weld the legs to a frame that ties all four together, but that's just me.
Re: Steel legs?
Re: Steel legs? You Could Buy Them
William Duffield
I built this one for a customer about 15 years ago. Obviously, it's flat sawn ash, stained.
The legs were threaded into plates supplied with the legs and screwed to the wooden supports. Screw holes holding the top to the cross braces were elongated, of course.
I think I like it better on the sawhorses. :b
Re: Steel legs?
Larry Rupprecht
Beautiful piece in its simplicity!
Re: Steel legs?
Try King Architectural Metals *LINK*
Gary Smyth
Four locations in LA, Dallas, Atlanta, Baltimore. They have numerous metal parts that are legs or can be made into legs. For example cast iron, aluminum, or forged steel metal balusters can, in the right context, make a strong and decorative leg. They also have the fittings to attach same. Much of what they offer is destined for stairs, railing, or fence applications but might be worth a look.
"Shop by category" button and type in legs or balusters, etc.
I believe that they will cut to length but ask about their tolerances.
http://www.kingmetals.com
Re: Steel legs?
Thanks all - lots to think about!
Re: Steel legs?
William Duffield
Thanks. It was fun trying to keep the figure in the adjacent boards harmonious.
Re: Steel legs?
pic of some steel legs I make
Robin Corell in Atascadero
here's a photo of a bar stool I made with steel legs. I also use the same legs and similar structure for tables. When I get some time I need to make a tv console for my own use. The legs are .063" wall 2" square tubing. I flare the foot and add a glide inside each leg. I tig weld the legs and stretches and then use an acid black finish.
Re: Steel legs?
Re: pic of some steel legs I make
TomD
Nice!
Re: Steel legs?
Re: Steel legs?
Jessecloud, do you happen to live near East TN? I have a metal fab room in my shop with cutting equipment, welders, grinders, press, taps, even a small milling machine and lathe - and I'm not afraid to share.
It might be a good education and all it would cost you would be the materials. I've never made steel legs for furniture but have made a bunch of things needing the same techniques. If you are far away, perhaps there is someone near you with similar facilities.
Re: Steel legs?
jessecloud
Very cool! How do you flare the bottom of the legs?
Re: Steel legs?
Re: Steel legs?
jessecloud
Thanks for the kind offer John. That's an education I would love to get!
Unfortunately, I live in the high desert of New Mexico, a long way from Eastern Tenn. Next time I go to the woodworker's club I'll ask around for a metal worker who shares!
Jess
Re: Steel legs?
Re: Steel legs?
Robin Corell in Atascader,ca
I use a jig saw to make an 8" cut about 1/4 from one edge. I then clamp the leg to a wood caul and drive an aluminum forming die in the end of the steel tubing. While the aluminium die is still in place I tack weld a pie shaped piece of .063 sheet in place. I remove the aluminum die and finish welding and then grind and finish flush. It takes me about 6hrs to make 4 legs starting with a 20' length of tube and finishing with legs ready for patina.
Re: Steel legs?
Barry W. Larson
Hi Robin:
Love your stool - if you don't mind I might borrow some aspects of it (mainly the flared legs) for a hall bench I am planning. Can you offer some insight on how you do the acid finish on the legs?
Cheers,
Barry W. Larson
Calgary, Alberta, Canada eh!
Re: Steel legs?
I use a product I get from triple S chemical, black F1407.
I think on this piece I diluted according to the instructions and sprayed it on using a paint sprayer, then rinsed and towel dried. It will flash rust but that will come off with a soft cloth. I then heated the metal up with a torch to to drive off the moisture from the pores of the metal, about 200-250 then while it's still warm I apply some paste wax.
Re: Steel legs?
Barry W. Larson
Thanks Robin. I'll have to see if I can get Triple S products in Canada or if I'll need to find a Canadian supplier of similar products.
Cheers,
Barry W. Larson
Re: Steel legs?
This is their web site: www.patinas.com
Re: Steel legs?
Thanks Robin.
