Finishing is one of my least favorite things
Keith Newton
I thought I had managed to spray the final coat of white paint on some mdf doors before heading off for the weekend last Friday. But Tuesday when I started to take them over to hang, it thought some needed another coat, so I sanded them all. Yesterday seemed like a perfect day to spray them, with the temp in the 70ies, so I opened both sets of double doors, with my spray table right up behind the big fan blowing out the back pair. This is a big 5' fan powered with a one hp motor, so it gets all the mist out instantly.
I hadn't given a good look at the weather forecast, but after shooting 10 of them, and setting them aside to dry, a sudden strong blast of wind blew through my back doors hard enough to slam the front pair a couple of times, taking turns with the fan pressure difference.
By the time the front had passed, my freshly painted doors looked a lot like sandpaper. I've sanded them down to where they feel good, but wondering if I've gone far enough. I'm sure you all know that whenever something lands on a wet finish, the surface tension pulls up a little peak, which also pulls a little crater around it.
My question for you finishing experts is, will those shiny little craters show through the next coat? Does the surface tension over the dull sanded part pull some finish out of those slick little depression, or do I need to keep sanding?
This is Benjamin Moore oil base enamel, semigloss, thinned for conventional spray.
