First for me- BS blade cracked!
Tony-Memphis
I've read stories, but this was the first time for me. I was cutting some small pieces and I started hearing a knock. Started the normal investigation protocol and saw nothing unusual. So, I spun the blade by hand and noticed a distinct bump. When I looked closer, I found a crack. After I removed the blade, it was very easy to finish the break. It was near the weld, but not right at the weld. Not sure how old, but it is a Highland Hardware 3/16 blade. I'm sure I've been using it a while. I don't abuse them and it probably doesn't have much run time. While I was inspecting, I noticed the lower thrust bearing didn't want to spin. It feels pretty rough. New blade and bearings on the way.... Still using the stock stuff with cool blocks. I've read that the fancy guides aren't worth the money. I wish the cool blocks fit better. Mine are small for the guide and they want to go all angled like when tightened. I glued a piece of veneer to two sides of the blocks to take up the slop. That works, but.... Glad it didn't snap while I was cutting...I'm sure that would have woken me up! Glad I had the old blade as a backup too. At least I could keep working.
Tony
