What to with walnut Butcher block tops????
At a freight auction I bought about half a dozen butcher block tops made out of walnut strips 1 3/4" square. They are 3' by 4'. Any suggestions on what to do with them? (Pretty crappy walnut, many strips have sapwood and some have the pith of the tree. One broke right in half.)
Re: What to with walnut Butcher block tops????
John Veerkamp
cut smaller for cutting boards. might be able to work around the bad parts. Sap wood not necessarily bad.
I thought of that.....
I probably will cut some down into cutting boards. I am wondering about blood grooves. Any suggestions on that? Traditionally I have made them with the center dished out about a 1/4". That makes them sit really nicely on the corners and if any juice runs off or the counter is wet, they don't develop the "suction" to the counter. What is a good size for a big cutting board?
I also thought about ripping some of them down and saving some of the nicer strips for slender legs and such. Sort of seems like sacrilege. Making little ones out of big ones.
Re: I thought of that.....
John Veerkamp
for veggies and fruit no groves necessary. I don't usually use wooden boards for meat. Another use in assorted sizes would be cheese serving trays. even smaller sizes where they have surface defects is trivets.
cutting boards can vary from 7X9 to 12X15. no such thing as a standard here.
Re: Turn them on the lathe into platters?
Yes, great for turning plates and platters.
Good for spindle turning. I cut up a surplus rock maple top made the same way back into the original sized stock for spindle turning
Make a very nice work surface for the shop. I'll take one. Please deliver.
Could be dicey. I would think that countertops would have been glued up with a moisture resistant glue, but it sounds like some pretty spotty QC on these. The upshot is, before you start making cutting boards and platters -- or actual counter tops -- you might want to torture a sample with moisture or steam to see how the glue lines hold up.
RE Cutting boards, in my experience, thick cutting boards are not handy. Wives don't like to have to schlep around a five-pound board, or wash it or stow it away. Small cutting boards -- say, like a 2" x 6" x 8" little cheese boards might be an exception. Or, if you have countertop space to spare, make a big stationary board and keep it there, ready for action. Still a little awkward to wash when necessary.
One possibility, if you have the right router bit and an overarm router, is to make a meat cutting board like this one that we've been using for the past 40 years. It is 1 1/2" thick -- and black walnut, by the way, but the slanted relief surface and thinned out hand holds on the ends cut the weight to a very manageable pound or so.
Or send those tops to me, and I'll use them for countertops in a kitchen I'm building. Unless they're really shabby. :)
John in NM
Make a router table top out of one. Everyone's gaga over cast iron, but I'd take a thick chunk of wood any day, better sound/vibration dampening.
12" X 15"
Mike Farinella
allows them to fit in most kitchen drawers..
Be careful turning if one fell apart already.
Since you have lots of them
Gary Smyth
I would take one and cut to fit on an existing work bench or old/new table as a exacto cutting and/or soldering station. Every shop needs one flat place dedicated to clean, slice, pound, burn, scorch, mini clamp, open, and mix stuff. If you don't already have such a place, a hefty beat-em-up top will serve you well for years and you won't feel bad with the scars because that's why it is there. No additional cost involved, little time invested, no finishing, decent work surface, lasting materials. If it gets too beat up turn it over or fill with Bondo. What it looks like for its new function is not important.
The one that broke.....
broke right down the pith of the tree.
Lots of good ideas, Thanks
Mike Jurnigan in Zuni
Barry,
I need a new radial arm saw top. I would be willing to buy 1 or 2 of them off of you. Send me an email if you would consider it.
Mike in Zuni, Va
Mike, I sent you an e-mail, let me know if you don't get it. I will be happy to sell you one.
