Couldn't find my 3M rubber sanding block,
Keith Newton
I'm in the process of finishing some cabinet doors, and needing to sand between coats. Last time I needed a new pad for my 6" random-orbit sander, I bought two, so when I couldn't find the normal 1/4 sheet block, I remembered having the extra pad, which I put into use by drilling and tapping a wooden block that fits my hand to screw on top.
After using it through two coats, I have to say that it beats anything I've ever used. It has just the right density, is very light, and uses the same disk that I keep on hand for power sanding.
Next time you have any delicate sanding, even if you don't have an extra pad laying around, I would encourage you to remove the one from your sander, to just give it a test drive. I think you will like it.
