Building a table saw sled for the first time.
Lee
I am wanting to build my first table saw sled. Came across a thread where a guy was showing off his new sled build and had mentioned an accident he had with the previous one. Something about letting go of the sled, it jumping up and rocketing back into his face. He's ok but it shook him up.
Got me thinking that I would post here and ask you the community for any first time sled building feedback regarding the construction, what you may do different if you were to build another, and safety.
Many thanks
Lee
Re: Building a table saw sled for the first time.
some sled ideas
I run a 7 1/2" CMT thin kerf industrial combination blade ($35) on the saw when I can (which is almost always). It doesn't have enough angular momentum to sling stuff like what you saw. The main risk on a sled is having the saw exit the back of the sled which is where it is natural, and not good, to push it from. Put a 3" piece of something back there. On mine I added a piece of aluminum which will make a racket if the blade hits it, just before maybe hitting my hand.
1/2" Baltic birch makes a nice sled body. Quarter grain hardwood for runners. Put runners in slots, add some drops of glue and set the plywood in place. When glue dries add screws from bottom. The hard part is getting the fence perfect square to blade. There is a geometry way to do it (drawing a perpendicular to a line with a compass. the saw kerf is the line and the fence the perpendicular.
Re: some sled ideas
tom gattiker
Years ago I built mine using a set of instructions from Highland Hardware's website. If I was making another one, I'd refer to those instructions again for sure. They were quite good
Jim Dillon
Lee, gosh, I can't imagine a properly constructed sled would be capable of jumping back at the operator. Maybe the runners were not tight in the TS grooves and it twisted somehow? Anyway, there are so many plans on the internet for sleds. Some fancy, and some plain. Size the width of the sled to what you anticipate cross cutting. I have three: 12, 18, and 27 inches wide. I use the 12 incher most often and just stick a 1/2 inch board under any long boards that extend off the sled. I also built my sleds from 1/2 inch baltic birch for the base and 2x1/2 inch baltic birch glued together for the front an rear fences. As Bill said, be darn sure you cover the blade exit area with something as it is way, way too easy to chop a thumb off or worse if you don't. I also made my rear fence high enough that I can fasten clamps to hold stop blocks etc. I made the runners from locust but only because I had a lot of it on hand. I also built a plastic plexiglass cover for the blade but never used it. Here, hopefully is a picture. I made several stops of varying length to allow repeatable crosscuts. These are really handy and I use them a lot. TS sleds are incredibly useful. Hope this helps. Jim
Edit: I also added a 1/8 inch saw kerf on the bottom of the rear fence to collect sawdust.
Bill Howatt
Jim's shows a stop being held with a clamp which is real handy for cutting more than one piece the exact same length.
I put about a 1" high strip of something like 100 grit sandpaper on the rear fence so the stock rests against it which helps hold it in the desired location.
Bill
Lee, Could you provide a link to the accident
Keith Newton
About the only way that I could imagine having a kick-back with a sled, would be if the slot wasn't cut all the way out the back end, then the user backed into the uncut part. Backing up while making a cut is tricky if you don't know how to control it.
Or, if he had a fairly large sled, then loaded something heavy onto it while it was hanging off the front, which could cause the far end to tip-up. If he caught it, but let it back down, essentially making a fast plunge cut, not in the existing slot, but off to one side. The blade could get some serious traction, then shoot the whole sled forward. The same could be true if someone was using a sled without an out feed table. Letting the sled feed past the tipping point, then jerking it back onto the blade, would give it the whole length of the sled to get traction on.
Without knowing the whole situation, there is no way to be sure, but sleds are generally pretty safe.
Highland Hardware plan for sled!
Ray Newman
TS sled plan that Tom G. mentioned:
www.highlandwoodworking.com/aslidingtableforyourtablesaw.aspx
jessecloud
Just thinking out loud, but one way the accident could have happened was when raising the blade to make the initial kerf in the sled. It needs to be clamped or otherwise held down firmly.
