Thoughts on TS sled size
Howard in Toronto
Hi All
My next project is a 6-ft cabinet. The top and bottom will have long bevels to mate up with the gables. The idea is a wrap-around effect for continuous grain.
As always I'll use sheet goods that I'll veneer myself.
Everything points to a track saw. But truly not desirable. Mainly because of the dollars involved. Or I can make a TS sled. Theoretically, it has the added benefit of long-term usefulness.
But it has to be a biggie - minimum 6-plus feet long and 42" wide. I figure I'll use 1/2" MDF for the base and UHMW for the runners.
Does anyone have any personal experience, ideas or suggestions. Or am just asking for waaaay too much aggro.
Thank you.
Howard
Re: Thoughts on TS sled size
Keith Newton
I wouldn't use MDF since it is so heavy, and not that strong. Use 1/2" plywood instead, and I wouldn't use uhmw for the runners either, since you can't glue it. There isn't anything wrong with just using a good hardwood, which if sized just right, is easy to apply straight. Cut it so it is quarter sawn to thee 3/4" face, and exactly the depth of the groove. You can spread the glue on it, then brad it at both ends, leaving the trailing brad partially out, so you can pull it. Then set it up on the saw, then shoot down from the top while you feed it along, letting the groove keep it straight, while you shoot down about half way across the front to back depth of the top. As you get to the trailing end, you'll probably need to pull the brad on the end to keep from jamming, so just finish out from above to the end.
Once the first is done, you can apply glue to the other, then shoot it on like the first as you feed it across the top, letting it be the guide. for the second.
Flip it over, and hammer it down, making sure there is a tight gap for the glue line. If in the future high humidity makes it too tight, I like to roll a burr on a cheap chisel, to use as a scraper. Look for the shine where it rubs too hard in the groove, and scrape off a little curl. Wax is your friend. You'll also need a table in front of the saw to hold it level while your getting your parts set up on it.
When I'm cutting stacks of veneer, this calls for a sharp fine tooth blade, and ZERO-CLEARANCE on each side underneath, so any blade change calls for a sacrificial 1/4" mdf top. It can be lightly bradded on, then moved over to tighten for another blade when needed.
Your, may be fine, but my longest is 8' x 24" wide, which has been wide enough for everything I've needed. If you need 6' now, how will you feel if you need 7' later and have to make another? As for the 42" width, if there is a reason you need that much, just do it, but if your having to jig up stops and or layout lines, you'll be reaching pretty far out in the middle. When I'm pilling weights on top of a platen on top of a stack of veneers, reaching that far would be a pain.
After just re-reading your post, I will also add that I have a couple of cross-cut sleds about the size you mentioned, and they do just fine for most of those needs, although I sometimes wish for more than 42" front to back when trying to jig up for long miters. The front and back fences that hold the halves together just get in the way on one end or the other.
Be sure to make the fences about 1.5" higher than your maximum blade height, so later when your using it to cut thick stock, there will be plenty left to hold it together.
Good luck, and just remember, "That which does not kill us, makes us stronger" Friedrich Nietzsche
Thank you Keith
Howard in Toronto
Everything you've said make me a little more confident.
And yes, as I continue to map out the order of the various cuts, infeed and outfeed surface are going to be key ingredients.
Howard
suggestion
the bigger the better. I would use 1/2" Baltic birch for weight and stability. quarter sawed oak or maple work fine for me. Mine is 4" x 3"
Re: Thank you Keith
Keith Newton
Do you have any drawings yet that you'd be willing to share? I'm not real clear on what you are shooting for, but I'd like to see what your thinking. Just drop me an email if you don't want to post them. Thanks.K
For sure, Keith
Howard in Toronto
Thank you Keith.
Coming over to you soon.
Howard
We know what you meant
Gary Smyth
when posted dimension at 3" x 4". The double prime mistake reminds me of the Stonehenge set in the very funny movie "Spinal Tap". Easy to do. Even NASA once used pounds measurement instead of metric Newtons to send a 125 million Mars probe into a fuel deprivation crash.
Mark
Howard, have you searched You Tube?
Lots of examples, designs, demo builds, and ideas from the most basic to more elaborate.
One example with plans available : https://www.youtube.com/watch?v=8sMVUS9mqI0
tom
Here is a idea I used on the last kitchen I built. The architect had some 8' tall cabinets that required me to use full length bevel/mitred corners. What I did was rough out the cut on the TS and then use a 45 degree router bit with a guide board for the bearing to make the final cut. It worked great!
