A smoother resaw
A smoother resaw
A smoother resaw
The current bandsaw thread is drifting a little low on the page, so I thought I would start a fresh one.
I mentioned there that there are two features we seek when resawing: the first is to saw straight, that is, that the blade does not wander. It is then possible to create veneers of even thickness, or minimise the waste when sawing away boards.
The second feature, which is the topic here, is to create a smooth surface, that is, one that requires the minimum planing or sanding. My question is what can one do to reach this goal (assuming the obvious, which is the bandsaw is set up optimally). I have one suggestion, and then will open the thread to the ideas of others ...
In my search for a smooth finish, I did try the blades sold by Highlands. They do produce a beautiful finish, one which requires little finish work. The one used in the picture below was a 1/2" ..
The problem with this blade was that it lasted only a short time. The wood I work with is very abrasive (contains high levels of similar), so your experience may differ. But, for this reason, I stick to bimetal (HSS) blades. The second reason for using bimetal is that I can resharpen these myself. I am doubtful I can do the same to carbide.
My bandsaw is a Hammer 4400 (17 1/2"), and the current resaw blade is a 1" wide Lenox Woodmaster, which has 1 1/2 tpi. When first used, the bandsaw/blade combination produced a dead-straight cut, however there were more saw marks than I considered desirable. My thought was that there was either an errant (or more) tooth with excess set, or that the blade had too much set altogether.
Unless something is really faulty, I do not send it back. I fix it myself.
The method I used to remove the excess set was to run a coarse diamond plate along the bandsaw blade.
Place the diamond plate against the fence and move thie fence/plate combination up against the blade so that it is just touching the outermost edge of the teeth. Ensure that the diamond plate is vertical, and clamp it in place.
Now run the blade past the plate by hand (spin the wheels). Do the same on the other side of the blade. Test the blade by resawing. Do this in very fine increments until you get the cut you want. Just be aware that some set is needed to avoid binding.
Other ideas, suggestions, or just comments?
Re: A smoother resaw
Brian Holcombe
Derek,
I bought two blades with my saw, a wood master CT 1.2T at 1" wide and the other is a bi-metal blade at about 4tpi.
I thought I would need both, I setup the saw originally with the bi-metal blade, but in speaking with the person who sold me the saw he requested me to remove the blade I was using and put the Woodmaster CT on. I did and I've not swapped back since.
I've cut 1/4" tall material all the way to something like 14" tall material with this blade already and it has not blinked.
I don't cut the sandpaper wood that you prefer to use :D , but I'm sure carbide will be an advantage there.
Why would be it be more difficult to sharpen carbide? You're using diamond files I presume? I can't speak for this blade, but I sharpen my festool carbide tip blades with a diamond file.
Brian, I would also have recommended you remove the 4 tpi blade :)
I have general use 1/2" bimetal blades that have 3 tpi. I would not go higher than that as they tend to accumulate sawdust, which loads the teeth and then they begin to wander. For resawing, 1 -2 tpi is usually recommended, with the lower mark more common in the wider blades.
With regards sharpening carbide blades, I've not tried. I've sharpened many bimetal blades, but was led to believe that carbide is difficult even with diamond (I use diamond disks in a Dremel).
Howard Pollack
It seems to me that the clean cutting of Highland's blade probably implies that the specifics of the tooth configuration is superior to others but that the wear implies that the steel is soft. Who makes Highland's blades and does that same company make a harder (bi-metal) blade with the same tooth configuration?
-Howard
Brian Holcombe
I was working under the impression that the 1.2 tpi blade would not cut thin stock, but since it has zero set it cuts thin stock quite well.
Carbide sharpens with diamonds, but use a cheap diamond plate, nothing you'd like to keep in good shape for other purpose.
The carbide teeth on a band saw are going to resist dulling about the same as for a table saw. Most of us don't saw anything close to the amount of stuff on a band saw as a table saw. So, Derek, if you are not seeing unacceptable wear rate on your table saw blade, don't fear a carbide band saw blade.
