The display case has an applied top. My preference is a bull nose banded plywood veneered top (so the end grain of solid wood would not be seen. ) This approach requires a 1" plywood substrate. Don't have one.
Can I vacuum glue a 1/4" plywood piece to a 3/4 plywood piece to get the 1"?
Certainly that could be done. The recommendations I have seen however have suggested a balanced sandwich, in this case two 1/2" thick pieces of plywood, has a better chance equalized stress and staying flat after the glue cures
Well, while it is suggested to always try to keep a balanced lay up, I don't think combining two already balanced plys of different thickness would be a problem, especially considering the nature of the piece. I mean, is isn't exactly like a long conference table top or something you'll ever be able to stand back and sight down, so I'd use what you've got, if it means not having to go buy a full sheet of 1/2"
You should be successful, this is something professional shops do all the time. I would use a glue that doesn't have much water in it. If you use good old yellow or white glue you introduce moisture inside the assembly. That moisture will reach the surface of the thinner side before it reaches the surface on the thick side and the panel could warp. Emphasis on the "could" because it is a risk and not a certainty. Even though I caution against that, I've done it but was careful to leave the panel on a flat surface with weights on top long enough for the glue to thoroughly dry.
If you use a vacuum bag and plastic resin glue you should be fine.
I think Bob Nailed it. My only concern would be moisture in the interior of the assembly. The glue layers in some plywood are fairly impervious, making it difficult for it to escape. May not be enough to matter, but it might be wise to use a low moisture glue. Contact cement or epoxy come to mind. I don't have a lot of faith in contact cement.
MDF comes in 1". Some of it coated with various substances. Never expands or contracts. Accepts veneer like it was made for it. I built a 21' three section dining table out of it 8 years ago and it is in play, defect free, as we speak. I did band the outside edge with 2 1/2" X 1" solid wood with a bullnose contour. Mortise and tenoned the banding.
