Veritas Depth Adjusters - Review and Discussion
William Duffield
I recently ordered and received a Veritas Slow Norris Depth Adjuster, Type A,
http://www.leevalley.com/us/wood/page.aspx?p=74068&cat=1,230,41182
which I retrofit into my Veritas Low Angle Adjustable Mouth Block Plane, 05P22.01
http://www.leevalley.com/us/wood/page.aspx?p=47881&cat=1,230,41182,45204,47881
I had always been a bit annoyed that it was was difficult to accurately set the thickness of the shaving on this plane. It was about the only thing I didn't like about the plane. The new adjuster has corrected this problem, and I am now quite pleased with its operation. I highly recommend it.
Now, all I need to do is find a use for the old, fast adjuster, but I have a couple of ideas. I can't, in conscience, sell it, because I had dropped the plane on the adjuster a long time ago, and bent the shaft. While I've straightened it out, mostly, and it functions as designed, I remain concerned that due to metal fatigue it may some day fail completely.
Lee Valley also sells a slow adjuster, 06P20.09, for their custom bench planes. I'm trying to decide whether I should put one of these slow adjusters in my custom #4-1/2. All three of the slow adjusters are shown on page 137 of their latest woodworking tools catalog. But online, there is no direct link from their standard bevel up planes to the slow adjusters. So far, I have not found a slow adjuster offered for their non-custom bevel down planes.
I wonder if they have considered offering the slow adjuster as an option when a new plane is ordered? Knowing what I know now (or at least what I think I know), I would prefer the slow adjuster to be the default option, or at least AN option, instead of an added expense, on all their planes. Their custom bench planes already have more options and choices than you can shake a stick at, so maybe adding another one would crash their ordering system. :D Picking a tote and knob for a custom bench plane can put you on the horns of a dilemma if you are trying to order one online. I would highly recommend visiting their booth at an event or walking into one of their retail stores.
Re: Veritas Depth Adjusters - Review and Discussion
Thanks William.
I have yet to try the slow adjusters. Your comments remind me to do so.
It may be of interest to some to read my review of the Veritas Custom planes, where I discuss the various options and how they affect ergonomics. There is a lot of information about the way we actually hold and use handplanes. The link is below:
http://www.inthewoodshop.com/ToolReviews/VeritasCustomPlanes1.html
TomD
I remember them sending slow adjusters out for one of their earlier planes, as a replacement. Maybe there is a super fast, fast and slow...
Seems like a low angle block type and a high angle plane might have different rates of feed on the adjuster so that X number of turns would cause the same projection. Something that operates at 90 like a scraper will have a 1-1 rate of feed, while a 15 degree block would have a 3.75-1 feed. That looks like a range that is far greater than fine and fast adjusters thread slopes.
Of course there are other factors than rate of feed: Feel; self-cleaning; backlash; ability to hold setting.
One thing that might be worth adding to the LV line up (patent pending), would be a drive extension for a drill driver so that large jumps could be run off a drill driver. Normally these don't occur, but if one is fritzing with multiple blades they are not all necessarily at the same wear point. When it comes to adjustments, fine is fun unless you have a big move to make.
