display case-It's glued
Twenty four dovetails had to come together at once. You bet I used liquid hide glue-Franklin Brand because it has the best stability, by far. Liquid hide is like greasing a joint. They slide together better than when dry. There is no tendency to seize up like with yellow glue.
Wife and I work together applying glue with brush and spatula. Joints are assembled one end at a time by forcing together with hand pressure and modest taps from a rubber mallet.
Once together, more or less, the assembly is placed on a flat surface, laying down, and clamps applied to snug the joints up tight. After snugging the clamps are removed and the assembly checked for square by measuring diagonals. A square can be misleading if any side is bowed even slightly, so measuring diagonals is the most assured test.
To my delight the assembly lays flat on a flat surface. Fitting doors should be easy. Remaining is adding the back, top, doors and the base unit with a drawer. Still undecided whether the back will be light wood or dark wood. I am thinking cut glass will display better with a dark background, but we'll test this assumption later.
Looking good Bill!
