Veneer Thickness Characteristics
Alan Young
Thanks for all the responses about my bandsaw blade question below- Now to a different but related topic. Veneer thickness characteristics. As I mentioned in my previous post my veneer work in the past has been with thinner veneers---ie .0024 or less. I have had overall acceptable success using veneers of this thickness in my vacuum press-probable because my panels were seldom longer than 36" or wider than 24"- meaning I could tape and glue-up my veneers and have them set flat in my press. As I anticipate cutting my own veneers in the future-My first question is-At what thickness does wood stop "behaving" as veneer and start "behaving" as solid lumber? This question has to do with moisture content and wood movement. Secondarily does the relationship of wood movement/thickness vary from species to species? and or type of cut ie quarter sawn vs flat sawn vs rift cut??? At this point I am thinking for a number of reasons-that I'd be aiming at veneers up to 3/16 thick....Knowing what "Behavior" I can expect from thicker veneer will effect the way I approach a couple of designs I have on the board---Thanks all
-Alan
