Display case- abnormal dovetails and some thoughts
Background- the frame sides will be held together by dovetailing a veneered top and bottom into them. To deal with this potential cross grain situation the top and bottom are veneered plywood. Dovetails will be cut into the plywood and the pins will be cut into grain running 90 degrees from normal.
To my surprise and delight the tails cut nicely in the 13 ply, plus two I added, birch plywood. It think it essential here that I used a birch core plywood. They even pared nicely during minor adjustment and they appear strong. I would not hesitate to cut dovetails in this kind of plywood in the future with either a cross cut or rip dovetail saw.
The pins started equally delightfully. I fretted, needlessly over starting the saw in the cross grain rails. As someone here suggested some time ago, I nicked the scribe line, set the cross cut saw in the nick and breezed through the cuts. (the nicks are highlighted with pencil) I recommend this nickers approach if you are having saw starting problems.
I wasted out much of the pin waste with the router and solid 1/4" carbide bit(recommended for this kind of work for longevity). The Lee Valley light proved its worth here. I could direct a focused beam of light on the kerf and scribe line and route to them easily. I do love this light and recommend it for this kind of work.
Next my good spirits were dashed. Paring out the tiny bit of remaining waste is trivial in a conventional, vertical grain pin. In this case end grain is being pared. In the earlier ash posts some spoke of how ash is softer than oak. NOT MY ASH. It is in another universe from the walnut and cherry I usually pare. Chisels had to be in perfect order to pare this end grain.....slowly!
Every experience one has leaned in paring conventional half-blinds is wrong in this situation. The grain orientations are exactly backwards from prior experience. It took hours to do one set of pins. I got slightly better by the 4th, but in all it took 2 days of tedious shop time to fit the tails to pins.
) and been the person making example, there is no offense taken on my part and hope that there is no offense taking on the part of any other participant here who might be made example of, in this case Bill.
