Weekend Entertainment *LINK*
Don Orr
So I had a little fun this weekend with a handsaw I picked up last weekend. It was in nice shape and priced right so I couldn’t resist. It’s a Pennsylvania Saw Corp. #400 complete with auxiliary handle. I cleaned it up a bit but it didn’t really need much. I studied the USDA “Crosscut Saw Manual” https://www.fhwa.dot.gov/environment/recreational_trails/publications/fs_publications/pdf/pdf77712508hi.pdf
on sharpening and setting and went to work. I don’t think this saw was used much or ever sharpened. I don’t claim to be an expert but have sharpened a few saws and even a smaller version of this one. I think it was actually a little easier working on these big teeth instead of tiny 14 ppi teeth. It didn’t really take much filing to get it cleaned up nicely and surprisingly sharp. The rakers were mostly in good shape and reasonably swaged although I did have to fix a few. I put on a coat of wax and made a quick blade guard out of some thin plywood. That was it for Saturday.
I had a project in mind just perfect for this saw. I take care of a small trail network in some state land near home and there was a fairly large tree that someone dropped directly across the trail at one point that had been bugging me for the last 2 years. The local forester does not allow me to use a chain saw on state land so this saw was just the ticket. I was not sure how good of a job I did with the sharpening but I was eager to give it a try. I loaded up my gear and headed up and was soon at the tree. I have no idea why someone would cut this particular tree as it even has trail markers on each side. It was obviously cut with a chainsaw. I actually did 2 cuts since the butt end was still resting on the stump. The 1st cut went well and freed up the end to drop with the next cut. I even set up my camera and shot a bit of video. It took about 5 minutes to cut through the 16-18” maple, but I think I was aided by the fact that the tree was beginning to decay some and it was not frozen. I rolled the block off the trail out of the way. I checked the chips to see how I did and found some long strings of chips just as the Manual showed so I know that at least some of the cutters and rakers were filed correctly. I can’t imagine trying to make a living with a saw like this like back in the old days. Those guys were tough! Check the video and you will even see a WoodCentral hat keeping me safe.
Last week I and 2 friends repositioned a foot bridge over a stream so it lines up with the trail again and is now useable. The state does almost nothing to maintain this property so it’s up to a few volunteers to pick up the slack.
https://youtu.be/iVU-N_kxVsw
Re: Weekend Entertainment *LINK*
Nice, saw, nice hat, and very kind of you to volunteer for this work, Don. I'll bet your biceps are really talking to you after a couple cuts like this.
On another note, the YouTube video following this one was of you paddling a kayak through Zoar Gap on the Deerfield River. I'm in total awe.
Cheers, and thanks for posting.
Ah, a video of the famous Don Orr in action! Looks like great exercise. Maybe I should ship to you that old 2-man crosscut saw in my shed. Hey, what's that white stuff all over the ground?
Don Orr
Thanks Ellis & John. Surprisingly my arms were not very sore-only 2 cuts totaled about 10 minutes. The trail work in not entirely altruistic as my wife and I use these ski trails often when we have snow (that's the white stuff John ;) ). Mostly this area is marsh and swamp in warmer weather and not fun to walk in but nice when things are frozen. Now I need to go back and fix a bunch of markers.
I don't think I'll go into business sharpening these saws though. Check out the Manual I linked to John and you will have yours back in shape in no time. It's fun.
And as for the kayaking, I'm still a rookie but that is a fun run for sure.
