Display cabinet- making a repair
Things happen and one needs to be able to recover from these set backs. In this case a corner chipped out of one of the bridle joints, I know not how.
I have had good success with repairs where I glue back in a scrap of wood to fill the vacancy. I have had poor success with any kind of filler and rarely use any .
I have learned to not throw out any scraps from a project until it's delivered. I rummaged until I found something with matching grain and color and sawed a small block of it for the repair. The ragged surface of the split was made smooth with a stroke of a chisel and the block glued in place.
Clamping repairs like these can be difficult to impossible and if you do clamp there is risk the clamp will force the repair piece out of position. Hence, I usually don't clamp. I have found rub joints to be about as strong as a clamped joint if the mating surfaces are perfect. In the current case, and most others, I applied glue, simply forced the repair into position with finger pressure and held it there for a minute. Yellow glue tacks quick and this technique anchors the repair securely.
It is important to then let the glue thoroughly set before shaving the excess of the repair away to level it. Shown is the result. The repair is in the upper corner of the male part of the joint.
