ADVERTISE HERE - FREE TRIAL
finish of antiques
finish of antiques
finish of antiques
Shelly Good
I have several antiques pieces of furniture. they all seem to have a dark, sometimes reddish, finish, that is usually opaque and does not show the grain. I need to redo them but not sure how to get the same look. I know how to strip, stain and seal, but not how pr what to use to get the more opaque look. I need some help and would be happy to send some pictures to explain this. Can you help me?? Shelly
Re: finish of antiques
Hello Shelly,
When you talk about opaque color that doesn't show the grain, I'm imagining twentieth century production furniture, not antiques. All the finer antiques I've examined have the grain in evidence, even when the stain color is quite dark. If you must have an opaque look, it is typically produced by spraying a suitable pigmented stain onto the bare wood and then topcoating with sprayed lacquer.
Ellis Walentine, Host
Shelly Good
I do appreciate your help.. is there a way for me to send you some pictures to show you what I mean? an email address??
Sounds
like you might have a piece with cinnibar lacquer. Is it of Asian style? Need not be Chinese as it could be a 19th Century "chinoiserie" when Europeans, especially the French, discovered Asian design elements.
Got revived a bit during the 20th with some Art Deco items.
A picture would be of much help, especially a close-up of the piece.
don stephan
From reading books over the years and occasional visits with a long time refinisher neighbor, there are at least three ways to create an opaque finish, and likely they could be used in combination as well.
First would be essentially a thin paint on the surface of the wood, then topcoated. Second would be a thick glaze applied over a layer of finish, then topcoated. Third would be a pigmented finish. It's possible a stain or dye was an initial color application, but usually these do not result in an opaque layer of color by themselves.
More than once I've read that some commercial kitchen cabinets can have three or four or more different layers of color intermixed with layers of sealer and/or finish.
Experimenting on similar scrap wood will be very important. How important is it to come close to the existing look, what experience do you have, and do you have spray equipment?
