Display cabient- gluing the frames
Shown are the aides for gluing. The cup is to dispense glue from. I chose to use yellow glue for these joints because it is a bit stronger in this application than the more forgiving liquid hide. But it is way less forgiving in assembly. Assembly has to go quickly or there will be seizure problems. I find it essential to label the mating joints, in this case with blue tape, so there is no hesitation about what mates with what when assembling them.
There was a recent article somewhere on cleaning up glue after gluing. It is better to develop techniques where clean up is unnecessary and that involves being smart about glue application. For example, for the bridle joint I slather glue on the female part with the spatula. I paint a THIN coat on the male part and promptly slide the joint together. ( I always coat both surfaces to ensure essential wetting of both surfaces. ) Any excess glue on the female part gets pushed harmlessly to the outside where it easily is wiped off and later cleaned up when the frame edge is planed. So little glue coats the male joint that none is squeezed into the inside corner where it would be difficult to remove.
Assembly is less risky if the joint is properly sized. It should go together easily with hand forces before the glue is applied. This tip is the most important thing I learned during my stint in the Headley shop.
After the frame is assembled the joints are clamped to bring them snugly together. Then the clamps are removed and the assembly checked to see that it is square. If these kinds of shouldered joints are made accurate they naturally come together square. Otherwise a diagonal clamp will adjust the squareness.
The frame is left to cure free of the clamps. Clamps can distort an assembly leaving one to guess how it will recover when the glue is dry and the clamps come off. An assembly should not be forced into submission during glue cure. Fix whatever needs fixing before the glue is applied.
My primary fear is that when the case is assembled that the front will not be in one plane. It must be for the doors to work properly. After both side frames were done I clamped them together and planed them to mate perfectly. The frames came together well and there was little adjustment.
Now it is on to a difficult dovetailing step to joint the frame sides to the top and bottom.
