Have a question? Ask Woody!
Preparing bridle joints for display case
The display case has frame and glass sides as well as doors, solid panel back and top and bottom dovetailed into the frames. The frames are assembled with bridle joints. Why not conventional mortise and tenon? Good question. There was an article in Fine Woodworking on sawing this joint that may have influence the decision. The Cabinet is Krenov inspired and he seemed to use bridle joinery.
I used bridle joints with good success on the door of the Krenov style wall cabinet shown.
I tried hand sawing these long joints in ash. It didn’t go well and I reverted to the trusty band saw. What was not obvious at the time was the extreme accuracy required for these long bridle joints so that the frame came out flat. Doing it over I would use mortise and tenon for these frames.
I cut both the male and female joint on the band saw. I cut the male part of the joint first and cut the female part to fit the male part. One can also cut the female joint first and fit the male part to it, something I always do on a mortise and tenon joint. Why I did the bridle joint the other way remains a mystery to me.
One side of the joint was sawed, the piece flipped and the second side sawed. A problem with this approach is that variance in stock thickness gets reflected in the thickness of the male part and width of the female part. There are only a few thousandths of an inch difference between a joint too tight and a joint too loose, so these tiny differences become important. Another problem is that errors creep in and the faces of the assembled joint may not be in perfect registration. Thankfully I can plane the high side to meet the low side to achieve a flush assembled joint. I wish I could figure out how to make perfect joints without adjustment but this ability has escaped me so far.
My crutch is to cut both mortise and tenon and bridle joints slightly too tight. It is critical which face of the joint is established by the band saw fence. Shown is the fence set up for the female part of the joint. After the initial cut I dry fit the joint or attempt to. After adding a shim to the fence, in the form of plastic sheet, I can then resaw the joint face. Resawing with shim widens the width of the joint according to the thickness of the shim and it moves the center of the joint by the width of the shim. By selecting the optimum shim thickness as well as which side to saw, or both, the joint tightness and registration can be adjusted.
The plastic used for blister packaging makes useful shims, as well as cardboard, stiff paper, etc. I keep an envelope full of these shims. Of course the male part can be adjusted by the same procedure if the male joint is made last instead of the female part. Tiny adjustments to the male part can also be made with a plane, chisel or file. In the current case a shim in the range of 0.008 to 0.012” provided a perfect fit and good enough registration of the mating pieces.
After the faces of the male joints are made the waste is sawed off almost to the shoulder scribe line and the rest removed with a chisel. I have never been able to get a crisp joint sawing to the shoulder line, hence, I always chisel to establish the shoulder.
After what seemed to be endless micro-adjustments to the band saw the joints came out ok. BTW, when preparing frame stock I prepared stock of the same thickness for making test joints to aide setting up the band saw.
Re: Preparing bridle joints for display case
You have more respect for your bandsaw than I have for mine. If I tried to cut those joints on my bandsaw, I would assume I was just wasting the lumber. Obviously I need to tune up the saw and get a better blade and improve my attitude.
The bridle joints I have cut, I cut them on the tablesaw, using a tenon jig. I use a "flat top" blade and shims to avoid having to reset the jig and to be able to index off one face.
Thanks for the post.
Brian Holcombe
Bill,
Do you flip the board or reset the saw and use one reference face?
I've taken to bandsawing these joints for my picture frame supports, I use one reference face and saw to the lines (grazing the scribe mark) and they almost always fit right off the saw.
"Do you flip the board or reset the saw and use one reference face?
I've taken to bandsawing these joints for my picture frame supports, I use one reference face and saw to the lines (grazing the scribe mark) and they almost always fit right off the saw. "
yes and maybe to all the questions and statements. Your way is the way to strive for.
Background, I have only done bridle joints once before so I was feeling my way around this time. If it ever becomes a joint I use much I will settle on something. In this instance I flipped because I knew I would be doing some fitting after the fact. The frame stiles were all matched. This was a tense operation as I did not have any extra lumber to recover from a mistake. The security blanket of oversize and fit reduced the stress.
I used to do tenons like Barry described with a spacer board sized to fit my mortise chisel- saw from a reference side. I recently started doing tenons on the band saw. On lumber that takes good marks I would saw to a scribe line as you describe. It's quick to set up. But I have had a difficult time marking this rift ash and then seeing the mark marked. Pencil darkening gets in the pores and can make black smudges in the end. Because it gets hidden I resorted to pencil for the dovetails and hoping I could saw to the edge of a line.
Mark Hennebury
You can trim the tenon up with a router mounted in a table. Rise a straight cut large diameter router bit up whatever you shoulder depth is and skim your tenon then flip and skim the other side. Use a fence to prevent damaging the shoulder.
The mortise part you could do with a table saw if you can put on a large enough blade. Preferably not a thin kerf.
Flip or spacers:
As for which method to choose; If you flip boards for the second cut, you will center the cut of tenon, or mortise, but you will have the possibility of dealing variations in stock size affecting the size of the finished piece.
Most of the time it is best to work from a single reference face and use spacer shims to do the second cut. that way all of your reference faces line up all of the joints will be the same size, any variation will only be in the stock size on the other face.
