ADVERTISE HERE - FREE TRIAL
Close to an adjustable knife hinge. *LINK*
Dick Coers
Like I said, kinda close. Anyone seen these in person? I sure like the looks of them. Some deep routing in the case, but with some templates, it looks doable with hand held.
PDF with dimensions.
http://www.salice.com/salice/file/public_admin/Air-USA_Ed02_03-2016-224.pdf
https://www.youtube.com/watch?v=4nUSzFQ1CfA
Re: Close to an adjustable knife hinge. *LINK*
Way cool. I haven't seen them in person. Thanks for the heads up. I am late to the Euro hinge binge. I had not heard of Salice, but a friend tells me they are the inventor of the Euro hinge. No idea if that is true, but I used them on a job that had 35 doors and they were really nice and well made. Other than, like some others here, I hate the appearance, I would use them again. These look like a serious improvement in the appearance. Wonder if any of them a demountable?
That slot appears to be 10 mm by 42mm in the case and must be accurate because the hinge body indexes off it. Serious stuff with a hand held. Not just a slot either.
Wonder if you could do it with a Domino?
Ralph Lipeles
I believe that I have seen them on better quality cigar humidors.
You're talking about Quadrant hinges
Dick Coers
Similar, but no adjustment on quadrants. These Salice Air hinges are new on the market.
Jim Dillon
Very interesting Dick. I've installed Quadrant (Brusso) hinges on a jewelry box and a humidor and thought they were kind of fussy to install though pretty to look at when finished. These seem to supply a more "finished" look to cabinet doors if one is considering using standard European hinges. Barry's idea to use a Domino would be an interesting idea to pursue to speed installation up, especially if one was installing a lot of doors in, say, a kitchen. Thanks for letting us know of this new product. Jim
Marc in Mass
This is the Brusso version which I think is as good as you can get in the hardware offerings of today. Rockler has a guide for cutting it in.
William Duffield
Fussy? Watch the videos that Dick linked to. These new hinges are completely beyond the capabilities of mortal men. :) The only practical way to install them is with a CNC machine, which is what they were designed for. Of course, the other side of that coin is that they are intended (as are most Euro hinges) to be installed on site and the fit between door and cabinet finely adjusted by semi-skilled labor. Their advantage over other Euro hinges is that they take up no room inside the cabinet. I don't understand the comment about their being the choice for high-end humidors. If I were building custom high-end humidors, I would consider the only viable choice to be Brusso quadrant hinges.
EdSnow
I have four pairs on my desk right now. They will probably stay there for a while, just too pricey for today. Also sort of limited in scope as the throw over is limited to 7/8 of an inch, meaning it can't be used on a 1" side of a wardrobe cabinet or something similar. 1" core is pretty common in high end custom. Also, so much worse to adjust than a normal euro. There is tremendous internal tension which makes adjusting the screws to move the hinge around a risky proposition. Even with a square drive the heads are about ready to strip.
About the only value I see in them is a full doors over drawers situation. Typical euro hinges require you to gap the drawer stack around the hinge or space the suspension off the side. When you look at the cost from the perspective of removing individual finished fronts and hardware the justification gets a little easier but still too rich for my blood.
Practical limit of the adjustment is +/- 1mm.
Good to know.  Thanks Ed.
