What saw for dovetailing Baltic Birch
cross cut or rip? If someone knows it will save me a research project.
Hand saw?
Re: What saw for dovetailing Baltic Birch
I usually use a Dozuki - which can either come in crosscut or rip. The one I use is a crosscut saw.
It didn't make much difference
15 tpi LN dovetail saw vs LV 16 tpi crosscut.
William Duffield
I would use a crosscut. I think a rip saw would tend to follow the layers that it is ripping, and be deflected by the adjacent layers that it is crosscutting, making it more difficult to control. OTOH, BB is full of glue, which tends to dull saw teeth faster, and crosscut saws are more difficult to resharpen.
Maybe Derek will offer us observations on his sawing of sheoaks and silky oaks, which have a very high density of parenchyma, and therefore work a lot like plywood.
No saw recommendation
Gary Smyth
I recently had a battle with Baltic Birch. I started using my Leigh Jig with poor result. I tried a newly purchased Whiteside drawer joint router bit. Everything I tried chipped out the Baltic Birch so badly it was unusable. Picture @ 300%.
The drawer sides are 12mm so I didn’t have much room for a sliding dovetail. I’m not good with hand cut dovetails so I don’t have a saw recommendation for you.
I still had seven drawer/trays to make, a December holiday deadline, a very cold shop, and I was plowing through too much wood. I was frustrated. I went finally with a fourth alternative rabbet and dowel. These are 10’’ x 16” x 3” interior trays with a fully trapped bottom running on 75lb, over travel , ball bearing drawer slides inside a 82" tall pantry carcass. The dowels are 3/16 birch.
So far so good. Each drawer is used maybe three times a week. Each holds about 12 to 15 pounds or about a dozen can weight maximum. Items vary from spaghetti sauce to coffee, canned goods, rice, pasta, salad dressing. With a little care it should hold.
If you have a lightweight application, the Baltic Birch is not cooperating, and aren’t offended by not using dovetails you might wish to consider other joinery.
Re: No saw recommendation
TomD
Here is a pick of an end block, neck joint. I had it on an experimental body that I later harvested for wood. You can sorta see the dovetail beneath the residue. They are angled dovetails to boot, though given that they are glued with epoxy there is little need for them to be tight, but they came out that way.
These are dovetails in a wood oven I use from time to time to keep guitar parts warm in the shop. They are pretty tight though they were undercut and glued with brown glue so the effect is messy, but then who dovetails their plywood boxes.
